Retrieve user accounts in the cluster
Retrieves a list of user accounts in the cluster to manage and review access configurations.
HTTP method and endpoint
GET /security/accounts
Introduced in
ONTAP 9.6
Related ONTAP commands
security login show
Learn more
scope |
string |
query |
False |
Filter by scope
name |
string |
query |
False |
Filter by name
comment |
string |
query |
False |
Filter by comment
role.name |
string |
query |
False |
Filter by role.name
applications.is_ldap_fastbind |
boolean |
query |
False |
Filter by applications.is_ldap_fastbind
applications.is_ns_switch_group |
boolean |
query |
False |
Filter by applications.is_ns_switch_group
applications.authentication_methods |
string |
query |
False |
Filter by applications.authentication_methods
applications.second_authentication_method |
string |
query |
False |
Filter by applications.second_authentication_method
applications.application |
string |
query |
False |
Filter by applications.application
locked |
boolean |
query |
False |
Filter by locked
owner.name |
string |
query |
False |
Filter by owner.name
owner.uuid |
string |
query |
False |
Filter by owner.uuid
password_hash_algorithm |
string |
query |
False |
Filter by password_hash_algorithm
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[account] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"applications": [
"application": "string",
"authentication_methods": [
"string"
"second_authentication_method": "string"
"comment": "string",
"name": "joe.smith",
"owner": {
"name": "svm1",
"password_hash_algorithm": "sha512",
"role": {
"name": "admin"
"scope": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
account_application
application |
string |
Applications |
array[string] |
is_ldap_fastbind |
boolean |
Optional property that specifies the mode of authentication as LDAP Fastbind. |
boolean |
Optional property that specifies whether the user is an LDAP or NIS group. |
string |
An optional additional authentication method for multifactor authentication (MFA). This property is only supported for SSH (ssh) and Service Processor (service_processor) applications. It is ignored for all other applications. Time-based One-Time Passwords (TOTPs) are only supported with the authentication method password or public key. For the Service Processor (service_processor) application, none and publickey are the only supported enum values. |
owner
Owner name and UUID that uniquely identifies the user account.
_links |
name |
string |
uuid |
string |
role
_links |
name |
string |
Role name |
account
_links |
applications |
array[account_application] |
comment |
string |
Optional comment for the user account. |
locked |
boolean |
Locked status of the account. |
name |
string |
User or group account name |
owner |
Owner name and UUID that uniquely identifies the user account. |
string |
Password hash algorithm used to generate a hash of the user's password for password matching.To modify "password_hash_algorithm", use REST API "/api/security/authentication/password". |
role |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
