Retrieve user accounts in the cluster
Retrieves user accounts in the cluster to view the existing accounts and their configuration details. This helps in managing access and security settings effectively within the cluster environment.
HTTP method and endpoint
GET /security/accounts
Introduced in
ONTAP 9.6
Usage notes
Retrieves a list of user accounts in the cluster.
Related ONTAP commands
security login show
Learn more
password_hash_algorithm |
string |
query |
False |
Filter by password_hash_algorithm
applications.second_authentication_method |
string |
query |
False |
Filter by applications.second_authentication_method
applications.is_ns_switch_group |
boolean |
query |
False |
Filter by applications.is_ns_switch_group
applications.application |
string |
query |
False |
Filter by applications.application
applications.authentication_methods |
string |
query |
False |
Filter by applications.authentication_methods
applications.is_ldap_fastbind |
boolean |
query |
False |
Filter by applications.is_ldap_fastbind
role.name |
string |
query |
False |
Filter by role.name
scope |
string |
query |
False |
Filter by scope
owner.name |
string |
query |
False |
Filter by owner.name
owner.uuid |
string |
query |
False |
Filter by owner.uuid
comment |
string |
query |
False |
Filter by comment
locked |
boolean |
query |
False |
Filter by locked
name |
string |
query |
False |
Filter by name
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[account] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"applications": [
"application": "string",
"authentication_methods": [
"string"
"second_authentication_method": "string"
"comment": "string",
"name": "joe.smith",
"owner": {
"name": "svm1",
"password_hash_algorithm": "sha512",
"role": {
"name": "admin"
"scope": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
account_application
application |
string |
Applications |
array[string] |
is_ldap_fastbind |
boolean |
Optional property that specifies the mode of authentication as LDAP Fastbind. |
boolean |
Optional property that specifies whether the user is an LDAP or NIS group. |
string |
An optional additional authentication method for multi-factor authentication (MFA). This property is only supported for SSH (ssh) and Service Processor (service_processor) applications. It is ignored for all other applications. Time-based One-Time Passwords (TOTPs) are only supported with the authentication method password or public key. For the Service Processor (service_processor) application, none and publickey are the only supported enum values. |
owner
Owner name and UUID that uniquely identifies the user account.
_links |
name |
string |
uuid |
string |
role
_links |
name |
string |
Role name |
account
_links |
applications |
array[account_application] |
comment |
string |
Optional comment for the user account. |
locked |
boolean |
Locked status of the account. |
name |
string |
User or group account name |
owner |
Owner name and UUID that uniquely identifies the user account. |
string |
Password hash algorithm used to generate a hash of the user's password for password matching.To modify "password_hash_algorithm", use REST API "/api/security/authentication/password". |
role |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
