Retrieve user accounts in the cluster
GET /security/accounts
Retrieves a list of user accounts in the cluster.
Related ONTAP commands
security login show
Learn more
owner.uuid |
string |
query |
False |
Filter by owner.uuid |
owner.name |
string |
query |
False |
Filter by owner.name |
scope |
string |
query |
False |
Filter by scope |
role.name |
string |
query |
False |
Filter by role.name |
applications.authentication_methods |
string |
query |
False |
Filter by applications.authentication_methods |
applications.application |
string |
query |
False |
Filter by applications.application |
applications.second_authentication_method |
string |
query |
False |
Filter by applications.second_authentication_method |
comment |
string |
query |
False |
Filter by comment |
locked |
boolean |
query |
False |
Filter by locked |
name |
string |
query |
False |
Filter by name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[account] |
"next": {
"href": "/api/resourcelink"
"records": [
"applications": [
"application": "string",
"authentication_methods": [
"string"
"second_authentication_method": "string"
"comment": "string",
"name": "joe.smith",
"owner": {
"name": "svm1",
"password": "string",
"role": {
"name": "admin"
"scope": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
account_application
application |
string |
Applications |
array[string] |
string |
An optional additional authentication method for MFA. This only works with SSH as the application. It is ignored for all other applications. |
owner
Owner name and UUID that uniquely identifies the user account.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
role
_links |
name |
string |
Role name |
account
_links |
applications |
array[account_application] |
comment |
string |
Optional comment for the user account. |
locked |
boolean |
Locked status of the account. |
name |
string |
User or group account name |
owner |
Owner name and UUID that uniquely identifies the user account. |
password |
string |
Password for the account. The password can contain a mix of lower and upper case alphabetic characters, digits, and special characters. |
role |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
