List all authentication keys associated with the admin SVM
Retrieves the authentication keys associated with the admin SVM to manage and review key configurations for security purposes.
HTTP method and endpoint
GET /security/key-managers/{security_key_manager.uuid}/auth-keys/{key_id}
Introduced in
ONTAP 9.12
Usage notes
Retrieves a list of all authentication keys associated with the admin SVM.
Related ONTAP commands
security key-manager key query
Required properties
security_key_manager.uuid- UUID of the external key manager. -
key_id- Key ID of the authentication key to be deleted.
key_tag |
string |
query |
False |
Filter by key_tag |
security_key_manager.uuid |
string |
path |
True |
External key manager UUID |
key_id |
string |
path |
True |
Key ID of the authentication key to be deleted. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
key_id |
string |
Key identifier. |
key_tag |
string |
Optional parameter to define key-tag for the authentication key, length 0-32 characters. |
"href": "/api/resourcelink"
"key_id": "00000000000000000100000000000123456789asdfghjklqwertyuio123456780000000000000090",
"key_tag": "Authentication Key-01"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536074 |
No key servers found. |
65536828 |
External key management is not enabled for the SVM. |
65536856 |
65536896 |
External key management is not configured on the partner site. |
65538800 |
External KMIP DKMIP keymanager not configured on administrative Vserver. |
65538801 |
Internal error while accessing keymanager database. |
65538802 |
The UUID provided is not associated with the administrator SVM key manager. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
