List all authentication keys associated with the admin SVM
GET /security/key-managers/{security_key_manager.uuid}/auth-keys/{key_id}
Introduced In: 9.12
Retrieves the authentication key identified by the 'key_id' and associated with the admin SVM.
Related ONTAP commands
security key-manager key query
Required properties
security_key_manager.uuid- UUID of the external key manager. -
key_id- Key ID of the authentication key to be retrieved.
key_tag  |
string  |
query  |
False  |
Filter by key_tag  |
security_key_manager.uuid  |
string  |
path  |
True  |
External key manager UUID  |
key_id  |
string  |
path  |
True  |
Key ID of the authentication key to be retrieved.  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_timeout  |
integer  |
query  |
False  |
return_records  |
boolean  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
key_id  |
string  |
Key identifier.  |
key_tag  |
string  |
Optional parameter to define key-tag for the authentication key, length 0-32 characters.  |
security_key_manager  |
Security key manager object reference.  |
      "href": "/api/resourcelink"
  "key_id": "000000000000000002000000000001003aa8ce6a4fea3e466620134bea9510a10000000000000000",
  "key_tag": "Authentication-Key-01",
  "security_key_manager": {
    "uuid": "1cd8a442-86d1-11e0-ae1c-123478563434"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536828  |
External key management is not enabled for the SVM.  |
65536856  |
No key servers found for the SVM.  |
65536896  |
External key management is not configured on the partner site.  |
65538800  |
External KMIP DKMIP keymanager not configured on administrative Vserver.  |
65538801  |
Internal error while accessing keymanager database.  |
65538802  |
The UUID provided is not associated with the administrator SVM key manager.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
self_link
self  |
_links
self  |
_links  |
uuid  |
string  |
Key manager UUID  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
