REST API reference
List all authentication keys associated with the admin SVM
Retrieves authentication keys associated with the admin SVM to review the security configuration used for secure communications.
HTTP method and endpoint
GET /security/key-managers/{security_key_manager.uuid}/auth-keys/{key_id}
Introduced in
ONTAP 9.12
Usage notes
Retrieves the authentication key identified by the 'key_id' and associated with the admin SVM.
  • security key-manager key query
Required properties
  • security_key_manager.uuid - UUID of the external key manager.
  • key_id - Key ID of the authentication key to be retrieved.
key_tag
string
query
False
Filter by key_tag
string
path
True
External key manager UUID
key_id
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
self_link
key_id
string
Key identifier.
key_tag
string
Optional parameter to define key-tag for the authentication key, length 0-32 characters.
      "href": "/api/resourcelink"
  "key_id": "000000000000000002000000000001003aa8ce6a4fea3e466620134bea9510a10000000000000000",
  "key_tag": "Authentication-Key-01"
Status: Default
ONTAP Error Response Codes
Error Code Description
65536828
External key management is not enabled for the SVM.
65536856
No key servers found for the SVM.
65536896
External key management is not configured on the partner site.
65538800
External KMIP DKMIP keymanager not configured on administrative Vserver.
65538801
Internal error while accessing keymanager database.
65538802
The UUID provided is not associated with the administrator SVM key manager.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
