Retrieve a multi-admin-verify approval group
GET /security/multi-admin-verify/approval-groups/{owner.uuid}/{name}
Introduced In: 9.11
Retrieves a multi-admin-verify approval group.
owner.uuid |
string |
path |
True |
name |
string |
path |
True |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
approvers |
array[string] |
List of users that can approve a request. |
array[string] |
Email addresses that are notified when a request is created, approved, vetoed, or executed. |
name |
string |
Name of the approval group. |
owner |
The owner of the approval group. The only valid owner is currently the cluster. |
"approvers": [
"string"
"email": [
"string"
"name": "string",
"owner": {
"href": "/api/resourcelink"
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
owner
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
