REST API reference
Retrieve a multi-admin-verify approval group
GET /security/multi-admin-verify/approval-groups/{owner.uuid}/{name}
Introduced In: 9.11
Retrieves a multi-admin-verify approval group.
owner.uuid
string
path
True
name
string
path
True
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
approvers
array[string]
List of users that can approve a request.
email
array[string]
Email addresses that are notified when a request is created, approved, vetoed, or executed.
name
string
Name of the approval group.
owner
owner
The owner of the approval group. The only valid owner is currently the cluster.
  "approvers": [
    "string"
  "email": [
    "string"
  "name": "string",
  "owner": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
owner
_links
_links
name
string
The name of the SVM. This field cannot be specified in a POST or PATCH method.
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
