Retrieve a multi-admin-verify approval group
GET /security/multi-admin-verify/approval-groups/{owner.uuid}/{name}
Introduced In: 9.11
Retrieves a multi-admin-verify approval group.
owner.uuid  |
string  |
path  |
True  |
name  |
string  |
path  |
True  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
approvers  |
array[string]  |
List of users that can approve a request.  |
array[string]  |
Email addresses that are notified when a request is created, approved, vetoed, or executed.  |
name  |
string  |
Name of the approval group.  |
owner  |
The owner of the approval group. The only valid owner is currently the cluster.  |
  "approvers": [
    "string"
  "email": [
    "string"
  "name": "string",
  "owner": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
owner
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a POST or PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
