Retrieve all ongoing file move operations in the cluster
Retrieves information about all ongoing file move operations currently occurring in the cluster. This helps you monitor file movement and manage cluster resources effectively.
HTTP method and endpoint
GET /storage/file/moves
Introduced in
ONTAP 9.11
Usage notes
Retrieves all ongoing file move operations in the cluster.
Related ONTAP commands
volume file move show -
volume rebalance file-move show
max_throughput |
integer |
query |
False |
Filter by max_throughput |
is_destination_ready |
boolean |
query |
False |
Filter by is_destination_ready |
is_flexgroup |
boolean |
query |
False |
Filter by is_flexgroup |
uuid |
string |
query |
False |
Filter by uuid |
cutover_time |
integer |
query |
False |
Filter by cutover_time |
elapsed_time |
integer |
query |
False |
Filter by elapsed_time |
destination.path |
string |
query |
False |
Filter by destination.path |
destination.volume.uuid |
string |
query |
False |
Filter by destination.volume.uuid |
destination.volume.name |
string |
query |
False |
Filter by destination.volume.name |
destination.svm.uuid |
string |
query |
False |
Filter by destination.svm.uuid |
destination.svm.name |
string |
query |
False |
Filter by destination.svm.name |
is_snapshot_fenced |
boolean |
query |
False |
Filter by is_snapshot_fenced |
scanner.progress |
integer |
query |
False |
Filter by scanner.progress |
scanner.state |
string |
query |
False |
Filter by scanner.state |
scanner.total |
integer |
query |
False |
Filter by scanner.total |
scanner.percent |
integer |
query |
False |
Filter by scanner.percent |
source.path |
string |
query |
False |
Filter by source.path |
source.volume.uuid |
string |
query |
False |
Filter by source.volume.uuid |
source.volume.name |
string |
query |
False |
Filter by source.volume.name |
source.svm.uuid |
string |
query |
False |
Filter by source.svm.uuid |
source.svm.name |
string |
query |
False |
Filter by source.svm.name |
failure.message |
string |
query |
False |
Filter by failure.message |
failure.target |
string |
query |
False |
Filter by failure.target |
failure.code |
string |
query |
False |
Filter by failure.code |
failure.arguments.message |
string |
query |
False |
Filter by failure.arguments.message |
failure.arguments.code |
string |
query |
False |
Filter by failure.arguments.code |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
max_cutover_time |
integer |
query |
False |
Filter by max_cutover_time |
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
volume.name |
string |
query |
False |
Filter by volume.name |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
index |
integer |
query |
False |
Filter by index |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[file_move] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"cutover_time": 8,
"destination": {
"path": "d1/d2/file1",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"elapsed_time": 100,
"failure": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"index": 0,
"max_cutover_time": 10,
"max_throughput": 250000,
"node": {
"name": "node1",
"scanner": {
"percent": 80,
"progress": 80000,
"state": "string",
"total": 100000
"source": {
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"svm": {
"name": "svm1",
"uuid": "4fcb3159-a4ee-42b5-bb16-f752f2c430fc",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
destination
Destination file information.
path |
string |
svm |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
Contains the most recent failure reason for move operation.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
destinations
path |
string |
svm |
volume |
sources
path |
string |
svm |
volume |
files_to_move
A list of source files along with the destination file they are moved to. If the terminal path component of the destination is a directory, then the source file's basename is replicated in that directory. This is only used for FlexVol volume file move operations.
destinations |
array[destinations] |
The destination file information. |
sources |
array[sources] |
The source file information. |
node
Node hosting the destination of this move operation.
_links |
name |
string |
uuid |
string |
svm
SVM of the source reference file.
_links |
name |
string |
uuid |
string |
volume
Volume of the source reference file.
_links |
name |
string |
uuid |
string |
reference
Reference file information.
scanner
percent |
integer |
Scanner progress, as a percentage. |
progress |
integer |
Scanner progress, in bytes scanned. |
state |
string |
Status of the file move scanner. |
total |
integer |
Total bytes to be scanned. |
source
Source file information.
path |
string |
svm |
volume |
svm
SVM of the FlexGroup volume in file move operation. Only used in a FlexGroup volume file move operation.
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
uuid |
string |
file_move
Details of a file move operation.
cutover_time |
integer |
Time that the file move operation takes before cutover completes, in seconds. |
destination |
Destination file information. |
elapsed_time |
integer |
Time elapsed since the start of the file move operation, in seconds. |
failure |
Contains the most recent failure reason for move operation. |
index |
integer |
An additional unique element identifying one file among many that could possibly be moved as part of a job. File index is an identifier ordered by the file path arrays provided during create. For file move operations that involve only one file, the file-index value of zero is always correct. |
boolean |
Indicates whether the destination file is ready for use. |
is_flexgroup |
boolean |
Indicates whether this is a FlexGroup file move operation. |
boolean |
Indicates whether Snapshot copies are fenced. |
max_cutover_time |
integer |
The maximum amount of time, in seconds that the source can be quiesced before a destination file must be made available for read-write traffic. Not supported in FlexGroup volume file move operations. |
max_throughput |
integer |
Maximum amount of data, in bytes that can be transferred per second in support of this operation. A non-zero value less than 1 MB/s is set to 1 MB/s. A non-zero value greater than 1 MB/s is truncated to the nearest integral megabyte value. If unspecified, the default value is "0" which means no range is set for the data transfer. |
node |
Node hosting the destination of this move operation. |
scanner |
source |
Source file information. |
svm |
SVM of the FlexGroup volume in file move operation. Only used in a FlexGroup volume file move operation. |
uuid |
string |
The UUID which uniquely identifies the job that started this move operation. |
volume |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
