Retrieves all ongoing file move operations in the cluster
volume rebalance file-move show
GET /storage/file/moves
Introduced In: 9.11
Retrieves all ongoing file move operations in the cluster.
Related ONTAP commands
volume file move show -
cutover_time |
integer |
query |
False |
Filter by cutover_time |
scanner.percent |
integer |
query |
False |
Filter by scanner.percent |
scanner.state |
string |
query |
False |
Filter by scanner.state |
scanner.progress |
integer |
query |
False |
Filter by scanner.progress |
scanner.total |
integer |
query |
False |
Filter by scanner.total |
uuid |
string |
query |
False |
Filter by uuid |
is_snapshot_fenced |
boolean |
query |
False |
Filter by is_snapshot_fenced |
index |
integer |
query |
False |
Filter by index |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
is_flexgroup |
boolean |
query |
False |
Filter by is_flexgroup |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
destination.volume.uuid |
string |
query |
False |
Filter by destination.volume.uuid |
destination.volume.name |
string |
query |
False |
Filter by destination.volume.name |
destination.svm.name |
string |
query |
False |
Filter by destination.svm.name |
destination.svm.uuid |
string |
query |
False |
Filter by destination.svm.uuid |
destination.path |
string |
query |
False |
Filter by destination.path |
elapsed_time |
integer |
query |
False |
Filter by elapsed_time |
source.volume.uuid |
string |
query |
False |
Filter by source.volume.uuid |
source.volume.name |
string |
query |
False |
Filter by source.volume.name |
source.svm.name |
string |
query |
False |
Filter by source.svm.name |
source.svm.uuid |
string |
query |
False |
Filter by source.svm.uuid |
source.path |
string |
query |
False |
Filter by source.path |
failure.code |
string |
query |
False |
Filter by failure.code |
failure.message |
string |
query |
False |
Filter by failure.message |
failure.arguments.code |
string |
query |
False |
Filter by failure.arguments.code |
failure.arguments.message |
string |
query |
False |
Filter by failure.arguments.message |
failure.target |
string |
query |
False |
Filter by failure.target |
max_throughput |
integer |
query |
False |
Filter by max_throughput |
volume.uuid |
string |
query |
False |
Filter by volume.uuid |
volume.name |
string |
query |
False |
Filter by volume.name |
is_destination_ready |
boolean |
query |
False |
Filter by is_destination_ready |
max_cutover_time |
integer |
query |
False |
Filter by max_cutover_time |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[file_move] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"cutover_time": 8,
"destination": {
"path": "d1/d2/file1",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"elapsed_time": 100,
"failure": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"index": 0,
"max_cutover_time": 10,
"max_throughput": 250000,
"node": {
"name": "node1",
"scanner": {
"percent": 80,
"progress": 80000,
"state": "string",
"total": 100000
"source": {
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"svm": {
"name": "svm1",
"uuid": "4fcb3159-a4ee-42b5-bb16-f752f2c430fc",
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
destination
Destination file information.
path |
string |
svm |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
Contains the most recent failure reason for move operation.
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
destinations
path |
string |
svm |
volume |
sources
path |
string |
svm |
volume |
files_to_move
A list of source files along with the destination file they are moved to. If the terminal path component of the destination is a directory, then the source file's basename is replicated in that directory. This is only used for FlexVol volume file move operations.
destinations |
array[destinations] |
The destination file information. |
sources |
array[sources] |
The source file information. |
node
Node hosting the destination of this move operation.
_links |
name |
string |
uuid |
string |
svm
SVM of the source reference file.
_links |
name |
string |
uuid |
string |
volume
Volume of the source reference file.
_links |
name |
string |
uuid |
string |
reference
Reference file information.
scanner
percent |
integer |
Scanner progress, as a percentage. |
progress |
integer |
Scanner progress, in bytes scanned. |
state |
string |
Status of the file move scanner. |
total |
integer |
Total bytes to be scanned. |
source
Source file information.
path |
string |
svm |
volume |
svm
SVM of the FlexGroup volume in file move operation. Only used in a FlexGroup volume file move operation.
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
uuid |
string |
file_move
Details of a file move operation.
cutover_time |
integer |
Time that the file move operation takes before cutover completes, in seconds. |
destination |
Destination file information. |
elapsed_time |
integer |
Time elapsed since the start of the file move operation, in seconds. |
failure |
Contains the most recent failure reason for move operation. |
index |
integer |
An additional unique element identifying one file among many that could possibly be moved as part of a job. File index is an identifier ordered by the file path arrays provided during create. For file move operations that involve only one file, the file-index value of zero is always correct. |
boolean |
Indicates whether the destination file is ready for use. |
is_flexgroup |
boolean |
Indicates whether this is a FlexGroup file move operation. |
boolean |
Indicates whether Snapshot copies are fenced. |
max_cutover_time |
integer |
The maximum amount of time, in seconds that the source can be quiesced before a destination file must be made available for read-write traffic. Not supported in FlexGroup volume file move operations. |
max_throughput |
integer |
Maximum amount of data, in bytes that can be transferred per second in support of this operation. A non-zero value less than 1 MB/s is set to 1 MB/s. A non-zero value greater than 1 MB/s is truncated to the nearest integral megabyte value. If unspecified, the default value is "0" which means no range is set for the data transfer. |
node |
Node hosting the destination of this move operation. |
scanner |
source |
Source file information. |
svm |
SVM of the FlexGroup volume in file move operation. Only used in a FlexGroup volume file move operation. |
uuid |
string |
The UUID which uniquely identifies the job that started this move operation. |
volume |
error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
