REST API reference
Retrieve all ongoing file move operations in the cluster
GET /storage/file/moves
Introduced In: 9.11
Retrieves all ongoing file move operations in the cluster.
  • volume file move show
  • volume rebalance file-move show
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
is_flexgroup
boolean
query
False
Filter by is_flexgroup
is_destination_ready
boolean
query
False
Filter by is_destination_ready
is_snapshot_fenced
boolean
query
False
Filter by is_snapshot_fenced
failure.arguments.message
string
query
False
Filter by failure.arguments.message
failure.arguments.code
string
query
False
Filter by failure.arguments.code
failure.code
string
query
False
Filter by failure.code
failure.message
string
query
False
Filter by failure.message
index
integer
query
False
Filter by index
cutover_time
integer
query
False
Filter by cutover_time
scanner.percent
integer
query
False
Filter by scanner.percent
scanner.progress
integer
query
False
Filter by scanner.progress
scanner.state
string
query
False
Filter by scanner.state
scanner.total
integer
query
False
Filter by scanner.total
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
max_cutover_time
integer
query
False
Filter by max_cutover_time
source.path
string
query
False
Filter by source.path
source.svm.name
string
query
False
Filter by source.svm.name
source.svm.uuid
string
query
False
Filter by source.svm.uuid
source.volume.name
string
query
False
Filter by source.volume.name
source.volume.uuid
string
query
False
Filter by source.volume.uuid
elapsed_time
integer
query
False
Filter by elapsed_time
volume.name
string
query
False
Filter by volume.name
volume.uuid
string
query
False
Filter by volume.uuid
max_throughput
integer
query
False
Filter by max_throughput
uuid
string
query
False
Filter by uuid
destination.path
string
query
False
Filter by destination.path
destination.svm.name
string
query
False
Filter by destination.svm.name
destination.svm.uuid
string
query
False
Filter by destination.svm.uuid
destination.volume.name
string
query
False
Filter by destination.volume.name
destination.volume.uuid
string
query
False
Filter by destination.volume.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of Records
records
array[file_move]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "cutover_time": 8,
      "destination": {
        "path": "d1/d2/file1",
        "svm": {
          "name": "svm1",
        "volume": {
          "name": "volume1",
      "elapsed_time": 100,
      "failure": {
        "arguments": [
            "code": "string",
            "message": "string"
        "code": "4",
        "message": "entry doesn't exist"
      "index": 0,
      "max_cutover_time": 10,
      "max_throughput": 250000,
      "node": {
        "name": "node1",
      "scanner": {
        "percent": 80,
        "progress": 80000,
        "state": "string",
        "total": 100000
      "source": {
        "svm": {
          "name": "svm1",
        "volume": {
          "name": "volume1",
      "svm": {
        "name": "svm1",
      "uuid": "4fcb3159-a4ee-42b5-bb16-f752f2c430fc",
      "volume": {
        "name": "volume1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
destination
Destination file information.
path
string
svm
svm
volume
volume
code
string
Argument code
message
string
Message argument
error
Contains the most recent failure reason for move operation.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
destinations
Path for file move operation.
path
string
svm
svm
volume
volume
sources
path
string
svm
svm
volume
volume
files_to_move
A list of source files along with the destination file they are moved to. If the terminal path component of the destination is a directory, then the source file's basename is replicated in that directory. This is only used for FlexVol volume file move operations.
destinations
array[destinations]
The destination file information.
sources
array[sources]
The source file information.
node
Node hosting the destination of this move operation.
_links
_links
name
string
uuid
string
svm
SVM of the source reference file.
_links
_links
name
string
uuid
string
volume
Volume of the source reference file.
_links
_links
name
string
uuid
string
  • x-nullable: true
reference
Reference file information.
scanner
percent
integer
Scanner progress, as a percentage.
progress
integer
Scanner progress, in bytes scanned.
state
string
Status of the file move scanner.
total
integer
Total bytes to be scanned.
source
Source file information.
path
string
svm
svm
volume
volume
svm
SVM of the FlexGroup volume in file move operation. Only used in a FlexGroup volume file move operation.
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
uuid
string
  • x-nullable: true
file_move
Details of a file move operation.
cutover_time
integer
Time that the file move operation takes before cutover completes, in seconds.
destination
destination
elapsed_time
integer
Time elapsed since the start of the file move operation, in seconds.
failure
error
index
integer
An additional unique element identifying one file among many that could possibly be moved as part of a job. File index is an identifier ordered by the file path arrays provided during create. For file move operations that involve only one file, the file-index value of zero is always correct.
boolean
Indicates whether the destination file is ready for use.
is_flexgroup
boolean
Indicates whether this is a FlexGroup file move operation.
is_snapshot_fenced
boolean
Indicates whether snapshots are fenced.
max_cutover_time
integer
The maximum amount of time, in seconds that the source can be quiesced before a destination file must be made available for read-write traffic. Not supported in FlexGroup volume file move operations.
max_throughput
integer
Maximum amount of data, in bytes that can be transferred per second in support of this operation. A non-zero value less than 1 MB/s is set to 1 MB/s. A non-zero value greater than 1 MB/s is truncated to the nearest integral megabyte value. If unspecified, the default value is "0" which means no range is set for the data transfer.
node
node
scanner
scanner
source
source
svm
svm
uuid
string
The UUID which uniquely identifies the job that started this move operation.
volume
volume
returned_error
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
