REST API reference
Retrieve storage pools for the entire cluster
Accesses a collection of storage pools across the entire cluster to review the available storage resources.
HTTP method and endpoint
GET /storage/pools
Introduced in
ONTAP 9.11
Usage notes
Retrieves the collection of storage pools for the entire cluster.
  • storage pool show
capacity.disks.total_size
integer
query
False
Filter by capacity.disks.total_size
capacity.disks.disk.name
string
query
False
Filter by capacity.disks.disk.name
capacity.disks.usable_size
integer
query
False
Filter by capacity.disks.usable_size
capacity.disk_count
integer
query
False
Filter by capacity.disk_count
capacity.spare_allocation_units.count
integer
query
False
Filter by capacity.spare_allocation_units.count
capacity.spare_allocation_units.available_size
integer
query
False
Filter by capacity.spare_allocation_units.available_size
capacity.spare_allocation_units.syncmirror_pool
string
query
False
Filter by capacity.spare_allocation_units.syncmirror_pool
capacity.spare_allocation_units.size
integer
query
False
Filter by capacity.spare_allocation_units.size
capacity.spare_allocation_units.node.name
string
query
False
Filter by capacity.spare_allocation_units.node.name
capacity.spare_allocation_units.node.uuid
string
query
False
Filter by capacity.spare_allocation_units.node.uuid
capacity.used_allocation_units.current_usage
integer
query
False
Filter by capacity.used_allocation_units.current_usage
capacity.used_allocation_units.node.name
string
query
False
Filter by capacity.used_allocation_units.node.name
capacity.used_allocation_units.node.uuid
string
query
False
Filter by capacity.used_allocation_units.node.uuid
capacity.used_allocation_units.aggregate.name
string
query
False
Filter by capacity.used_allocation_units.aggregate.name
capacity.used_allocation_units.aggregate.uuid
string
query
False
Filter by capacity.used_allocation_units.aggregate.uuid
capacity.used_allocation_units.count
integer
query
False
Filter by capacity.used_allocation_units.count
capacity.total
integer
query
False
Filter by capacity.total
capacity.remaining
integer
query
False
Filter by capacity.remaining
storage_type
string
query
False
Filter by storage_type
health.unhealthy_reason.message
string
query
False
Filter by health.unhealthy_reason.message
health.unhealthy_reason.target
string
query
False
Filter by health.unhealthy_reason.target
health.unhealthy_reason.code
string
query
False
Filter by health.unhealthy_reason.code
health.unhealthy_reason.arguments.message
string
query
False
Filter by health.unhealthy_reason.arguments.message
health.unhealthy_reason.arguments.code
string
query
False
Filter by health.unhealthy_reason.arguments.code
health.state
string
query
False
Filter by health.state
health.is_healthy
boolean
query
False
Filter by health.is_healthy
nodes.name
string
query
False
Filter by nodes.name
nodes.uuid
string
query
False
Filter by nodes.uuid
name
string
query
False
Filter by name
uuid
string
query
False
Filter by uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
error
error
num_records
integer
Number of shared storage pools in the cluster.
records
array[storage_pool]
spares
array[storage_pool_show_spares]
    "next": {
      "href": "/api/resourcelink"
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
  "num_records": 1,
  "records": [
      "capacity": {
        "disks": [
            "disk": {
              "name": "1.0.1"
            "total_size": 0,
            "usable_size": 0
        "remaining": 0,
        "spare_allocation_units": [
            "available_size": 0,
            "node": {
              "name": "node1",
            "size": 0,
            "syncmirror_pool": "string"
        "total": 0,
        "used_allocation_units": [
            "aggregate": {
              "name": "aggr1",
            "current_usage": 0,
            "node": {
              "name": "node1",
      "health": {
        "state": "string",
        "unhealthy_reason": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
          "target": "uuid"
      "name": "string",
      "nodes": [
          "name": "node1",
      "storage_type": "string",
      "uuid": "string"
  "spares": [
      "checksum_style": "string",
      "disk_class": "solid_state",
      "disk_type": "string",
      "nodes": [
          "name": "node1",
      "size": 10156769280,
      "syncmirror_pool": "string",
      "usable": 9
Status: Default
ONTAP Error Response Codes
Error Code Description
10944513
Unable to retrieve shared disk capability information.
10944514
Unable to enable shared disk capability.
10944527
Storage pools are not supported in MetroCluster configurations.
10944528
Unable to retrieve MetroCluster configuration information.
11206662
There is no storage pool matching the specified UUID or name.
11206667
Storage pool feature is not enabled.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
self
disk
Reference to the constituent disk object.
_links
_links
name
string
storage_pool_disk
disk
disk
total_size
integer
Raw capacity of the disk, in bytes.
usable_size
integer
Usable capacity of this disk, in bytes.
node
Specifies what node can use this set of allocation units.
_links
_links
name
string
uuid
string
storage_pool_spare_allocation_unit
available_size
integer
The usable capacity of this set of allocation units.
count
integer
The number of spare allocation units on this node.
node
node
size
integer
Size of each allocation unit.
syncmirror_pool
string
The RAID SyncMirror Pool to which this allocation unit is assigned.
aggregate
The aggregate that is using this cache capacity.
_links
_links
name
string
uuid
string
node
The node hosting the aggregate using this set of allocation units.
_links
_links
name
string
uuid
string
storage_pool_used_allocation_unit
aggregate
aggregate
count
integer
The number of allocation units used by this aggregate.
current_usage
integer
The amount of cache space used by this aggregate.
node
node
capacity
disk_count
integer
The number of disks in the storage pool.
disks
array[storage_pool_disk]
Properties of each disk used in the shared storage pool.
remaining
integer
Remaining usable capacity in the flash pool, in bytes.
array[storage_pool_spare_allocation_unit]
Properties of spare allocation units.
total
integer
Total size of the flash pool, in bytes.
array[storage_pool_used_allocation_unit]
Information about the storage pool allocation units participating in the cache tier of an aggregate.
error
Indicates why the storage pool is unhealthy. This property is not returned for healthy storage pools.
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
health
Properties that outline shared storage pool health.
is_healthy
boolean
Indicates whether the storage pool is able to participate in provisioning operations.
state
string
The state of the shared storage pool.
unhealthy_reason
error
node_reference
_links
_links
name
string
uuid
string
storage_pool
_links
_links
capacity
capacity
health
health
name
string
Storage pool name.
nodes
array[node_reference]
Nodes that can use this storage pool for their aggregates.
storage_type
string
Storage type for the disks used to create the storage pool.
uuid
string
Storage pool UUID.
Available spares for stoarge pool.
checksum_style
string
The checksum type that has been assigned to the spares.
disk_class
string
Disk class of spares.
disk_type
string
Type of disk.
nodes
Nodes that can use the usable spares for storage pool.
size
integer
Usable size of each spare, in bytes.
syncmirror_pool
string
SyncMirror spare pool.
usable
integer
Total number of usable spares in the bucket. The usable count for each class of spares does not include reserved spare capacity recommended by ONTAP best practices.
  • example: 9
  • readOnly: 1
  • Introduced in: 9.12
