Retrieve storage pools for the entire cluster
Retrieves the collection of storage pools for the entire cluster. This helps you manage and monitor the available storage configurations effectively.
HTTP method and endpoint
GET /storage/pools
Introduced in
ONTAP 9.11
Related ONTAP commands
storage pool show
nodes.uuid |
string |
query |
False |
Filter by nodes.uuid |
nodes.name |
string |
query |
False |
Filter by nodes.name |
name |
string |
query |
False |
Filter by name |
uuid |
string |
query |
False |
Filter by uuid |
capacity.remaining |
integer |
query |
False |
Filter by capacity.remaining |
capacity.used_allocation_units.current_usage |
integer |
query |
False |
Filter by capacity.used_allocation_units.current_usage |
capacity.used_allocation_units.count |
integer |
query |
False |
Filter by capacity.used_allocation_units.count |
capacity.used_allocation_units.aggregate.uuid |
string |
query |
False |
Filter by capacity.used_allocation_units.aggregate.uuid |
capacity.used_allocation_units.aggregate.name |
string |
query |
False |
Filter by capacity.used_allocation_units.aggregate.name |
capacity.used_allocation_units.node.uuid |
string |
query |
False |
Filter by capacity.used_allocation_units.node.uuid |
capacity.used_allocation_units.node.name |
string |
query |
False |
Filter by capacity.used_allocation_units.node.name |
capacity.disks.usable_size |
integer |
query |
False |
Filter by capacity.disks.usable_size |
capacity.disks.total_size |
integer |
query |
False |
Filter by capacity.disks.total_size |
capacity.disks.disk.name |
string |
query |
False |
Filter by capacity.disks.disk.name |
capacity.disk_count |
integer |
query |
False |
Filter by capacity.disk_count |
capacity.total |
integer |
query |
False |
Filter by capacity.total |
capacity.spare_allocation_units.node.uuid |
string |
query |
False |
Filter by capacity.spare_allocation_units.node.uuid |
capacity.spare_allocation_units.node.name |
string |
query |
False |
Filter by capacity.spare_allocation_units.node.name |
capacity.spare_allocation_units.size |
integer |
query |
False |
Filter by capacity.spare_allocation_units.size |
capacity.spare_allocation_units.available_size |
integer |
query |
False |
Filter by capacity.spare_allocation_units.available_size |
capacity.spare_allocation_units.syncmirror_pool |
string |
query |
False |
Filter by capacity.spare_allocation_units.syncmirror_pool |
capacity.spare_allocation_units.count |
integer |
query |
False |
Filter by capacity.spare_allocation_units.count |
storage_type |
string |
query |
False |
Filter by storage_type |
health.state |
string |
query |
False |
Filter by health.state |
health.is_healthy |
boolean |
query |
False |
Filter by health.is_healthy |
health.unhealthy_reason.arguments.code |
string |
query |
False |
Filter by health.unhealthy_reason.arguments.code |
health.unhealthy_reason.arguments.message |
string |
query |
False |
Filter by health.unhealthy_reason.arguments.message |
health.unhealthy_reason.message |
string |
query |
False |
Filter by health.unhealthy_reason.message |
health.unhealthy_reason.code |
string |
query |
False |
Filter by health.unhealthy_reason.code |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
error |
num_records |
integer |
Number of shared storage pools in the cluster. |
records |
array[storage_pool] |
spares |
array[storage_pool_show_spares] |
"next": {
"href": "/api/resourcelink"
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"num_records": 1,
"records": [
"capacity": {
"disks": [
"disk": {
"name": "1.0.1"
"total_size": 0,
"usable_size": 0
"remaining": 0,
"spare_allocation_units": [
"available_size": 0,
"node": {
"name": "node1",
"size": 0,
"syncmirror_pool": "string"
"total": 0,
"used_allocation_units": [
"aggregate": {
"name": "aggr1",
"current_usage": 0,
"node": {
"name": "node1",
"health": {
"state": "string",
"unhealthy_reason": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"name": "string",
"nodes": [
"name": "node1",
"storage_type": "string",
"uuid": "string"
"spares": [
"checksum_style": "string",
"disk_class": "solid_state",
"disk_type": "string",
"nodes": [
"name": "node1",
"size": 10156769280,
"syncmirror_pool": "string",
"usable": 9
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10944513 |
Unable to retrieve shared disk capability information. |
10944514 |
Unable to enable shared disk capability. |
10944527 |
Storage pools are not supported in MetroCluster configurations. |
10944528 |
Unable to retrieve MetroCluster configuration information. |
11206662 |
There is no storage pool matching the specified UUID or name. |
11206667 |
Storage pool feature is not enabled. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
_links
self |
disk
Reference to the constituent disk object.
_links |
name |
string |
storage_pool_disk
disk |
Reference to the constituent disk object. |
total_size |
integer |
Raw capacity of the disk, in bytes. |
usable_size |
integer |
Usable capacity of this disk, in bytes. |
node
Specifies what node can use this set of allocation units.
_links |
name |
string |
uuid |
string |
storage_pool_spare_allocation_unit
available_size |
integer |
The usable capacity of this set of allocation units. |
count |
integer |
The number of spare allocation units on this node. |
node |
Specifies what node can use this set of allocation units. |
size |
integer |
Size of each allocation unit. |
syncmirror_pool |
string |
The RAID SyncMirror Pool to which this allocation unit is assigned. |
aggregate
The aggregate that is using this cache capacity.
_links |
name |
string |
uuid |
string |
node
The node hosting the aggregate using this set of allocation units.
_links |
name |
string |
uuid |
string |
storage_pool_used_allocation_unit
aggregate |
The aggregate that is using this cache capacity. |
count |
integer |
The number of allocation units used by this aggregate. |
current_usage |
integer |
The amount of cache space used by this aggregate. |
node |
The node hosting the aggregate using this set of allocation units. |
capacity
disk_count |
integer |
The number of disks in the storage pool. |
disks |
array[storage_pool_disk] |
Properties of each disk used in the shared storage pool. |
remaining |
integer |
Remaining usable capacity in the flash pool, in bytes. |
spare_allocation_units |
Properties of spare allocation units. |
total |
integer |
Total size of the flash pool, in bytes. |
used_allocation_units |
Information about the storage pool allocation units participating in the cache tier of an aggregate. |
error
Indicates why the storage pool is unhealthy. This property is not returned for healthy storage pools.
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
health
Properties that outline shared storage pool health.
is_healthy |
boolean |
Indicates whether the storage pool is able to participate in provisioning operations. |
state |
string |
The state of the shared storage pool. |
unhealthy_reason |
Indicates why the storage pool is unhealthy. This property is not returned for healthy storage pools. |
node_reference
_links |
name |
string |
uuid |
string |
storage_pool
_links |
capacity |
health |
Properties that outline shared storage pool health. |
name |
string |
Storage pool name. |
nodes |
array[node_reference] |
Nodes that can use this storage pool for their aggregates. |
storage_type |
string |
Storage type for the disks used to create the storage pool. |
uuid |
string |
Storage pool UUID. |
Available spares for stoarge pool.
checksum_style |
string |
The checksum type that has been assigned to the spares. |
disk_class |
string |
Disk class of spares. |
disk_type |
string |
Type of disk. |
nodes |
Nodes that can use the usable spares for storage pool. |
size |
integer |
Usable size of each spare, in bytes. |
syncmirror_pool |
string |
SyncMirror spare pool. |
usable |
integer |
Total number of usable spares in the bucket. The usable count for each class of spares does not include reserved spare capacity recommended by ONTAP best practices.
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
