Retrieve storage pools for the entire cluster
Retrieves the collection of storage pools for the entire cluster to review or manage available storage resources.
HTTP method and endpoint
GET /storage/pools
Introduced in
ONTAP 9.11
Related ONTAP commands
storage pool show
capacity.remaining |
integer |
query |
False |
Filter by capacity.remaining |
capacity.disks.disk.name |
string |
query |
False |
Filter by capacity.disks.disk.name |
capacity.disks.total_size |
integer |
query |
False |
Filter by capacity.disks.total_size |
capacity.disks.usable_size |
integer |
query |
False |
Filter by capacity.disks.usable_size |
capacity.used_allocation_units.node.name |
string |
query |
False |
Filter by capacity.used_allocation_units.node.name |
capacity.used_allocation_units.node.uuid |
string |
query |
False |
Filter by capacity.used_allocation_units.node.uuid |
capacity.used_allocation_units.current_usage |
integer |
query |
False |
Filter by capacity.used_allocation_units.current_usage |
capacity.used_allocation_units.count |
integer |
query |
False |
Filter by capacity.used_allocation_units.count |
capacity.used_allocation_units.aggregate.uuid |
string |
query |
False |
Filter by capacity.used_allocation_units.aggregate.uuid |
capacity.used_allocation_units.aggregate.name |
string |
query |
False |
Filter by capacity.used_allocation_units.aggregate.name |
capacity.disk_count |
integer |
query |
False |
Filter by capacity.disk_count |
capacity.total |
integer |
query |
False |
Filter by capacity.total |
capacity.spare_allocation_units.syncmirror_pool |
string |
query |
False |
Filter by capacity.spare_allocation_units.syncmirror_pool |
capacity.spare_allocation_units.available_size |
integer |
query |
False |
Filter by capacity.spare_allocation_units.available_size |
capacity.spare_allocation_units.node.name |
string |
query |
False |
Filter by capacity.spare_allocation_units.node.name |
capacity.spare_allocation_units.node.uuid |
string |
query |
False |
Filter by capacity.spare_allocation_units.node.uuid |
capacity.spare_allocation_units.count |
integer |
query |
False |
Filter by capacity.spare_allocation_units.count |
capacity.spare_allocation_units.size |
integer |
query |
False |
Filter by capacity.spare_allocation_units.size |
name |
string |
query |
False |
Filter by name |
health.unhealthy_reason.code |
string |
query |
False |
Filter by health.unhealthy_reason.code |
health.unhealthy_reason.arguments.message |
string |
query |
False |
Filter by health.unhealthy_reason.arguments.message |
health.unhealthy_reason.arguments.code |
string |
query |
False |
Filter by health.unhealthy_reason.arguments.code |
health.unhealthy_reason.message |
string |
query |
False |
Filter by health.unhealthy_reason.message |
health.state |
string |
query |
False |
Filter by health.state |
health.is_healthy |
boolean |
query |
False |
Filter by health.is_healthy |
uuid |
string |
query |
False |
Filter by uuid |
storage_type |
string |
query |
False |
Filter by storage_type |
nodes.name |
string |
query |
False |
Filter by nodes.name |
nodes.uuid |
string |
query |
False |
Filter by nodes.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
error |
num_records |
integer |
Number of shared storage pools in the cluster. |
records |
array[storage_pool] |
spares |
array[storage_pool_show_spares] |
"next": {
"href": "/api/resourcelink"
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"num_records": 1,
"records": [
"capacity": {
"disks": [
"disk": {
"name": "1.0.1"
"total_size": 0,
"usable_size": 0
"remaining": 0,
"spare_allocation_units": [
"available_size": 0,
"node": {
"name": "node1",
"size": 0,
"syncmirror_pool": "string"
"total": 0,
"used_allocation_units": [
"aggregate": {
"name": "aggr1",
"current_usage": 0,
"node": {
"name": "node1",
"health": {
"state": "string",
"unhealthy_reason": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"name": "string",
"nodes": [
"name": "node1",
"storage_type": "string",
"uuid": "string"
"spares": [
"checksum_style": "string",
"disk_class": "solid_state",
"disk_type": "string",
"nodes": [
"name": "node1",
"size": 10156769280,
"syncmirror_pool": "string",
"usable": 9
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10944513 |
Unable to retrieve shared disk capability information. |
10944514 |
Unable to enable shared disk capability. |
10944527 |
Storage pools are not supported in MetroCluster configurations. |
10944528 |
Unable to retrieve MetroCluster configuration information. |
11206662 |
There is no storage pool matching the specified UUID or name. |
11206667 |
Storage pool feature is not enabled. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
_links
self |
disk
Reference to the constituent disk object.
_links |
name |
string |
storage_pool_disk
disk |
Reference to the constituent disk object. |
total_size |
integer |
Raw capacity of the disk, in bytes. |
usable_size |
integer |
Usable capacity of this disk, in bytes. |
node
Specifies what node can use this set of allocation units.
_links |
name |
string |
uuid |
string |
storage_pool_spare_allocation_unit
available_size |
integer |
The usable capacity of this set of allocation units. |
count |
integer |
The number of spare allocation units on this node. |
node |
Specifies what node can use this set of allocation units. |
size |
integer |
Size of each allocation unit. |
syncmirror_pool |
string |
The RAID SyncMirror Pool to which this allocation unit is assigned. |
aggregate
The aggregate that is using this cache capacity.
_links |
name |
string |
uuid |
string |
node
The node hosting the aggregate using this set of allocation units.
_links |
name |
string |
uuid |
string |
storage_pool_used_allocation_unit
aggregate |
The aggregate that is using this cache capacity. |
count |
integer |
The number of allocation units used by this aggregate. |
current_usage |
integer |
The amount of cache space used by this aggregate. |
node |
The node hosting the aggregate using this set of allocation units. |
capacity
disk_count |
integer |
The number of disks in the storage pool. |
disks |
array[storage_pool_disk] |
Properties of each disk used in the shared storage pool. |
remaining |
integer |
Remaining usable capacity in the flash pool, in bytes. |
spare_allocation_units |
Properties of spare allocation units. |
total |
integer |
Total size of the flash pool, in bytes. |
used_allocation_units |
Information about the storage pool allocation units participating in the cache tier of an aggregate. |
error
Indicates why the storage pool is unhealthy. This property is not returned for healthy storage pools.
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
health
Properties that outline shared storage pool health.
is_healthy |
boolean |
Indicates whether the storage pool is able to participate in provisioning operations. |
state |
string |
The state of the shared storage pool. |
unhealthy_reason |
Indicates why the storage pool is unhealthy. This property is not returned for healthy storage pools. |
node_reference
_links |
name |
string |
uuid |
string |
storage_pool
_links |
capacity |
health |
Properties that outline shared storage pool health. |
name |
string |
Storage pool name. |
nodes |
array[node_reference] |
Nodes that can use this storage pool for their aggregates. |
storage_type |
string |
Storage type for the disks used to create the storage pool. |
uuid |
string |
Storage pool UUID. |
Available spares for stoarge pool.
checksum_style |
string |
The checksum type that has been assigned to the spares. |
disk_class |
string |
Disk class of spares. |
disk_type |
string |
Type of disk. |
nodes |
Nodes that can use the usable spares for storage pool. |
size |
integer |
Usable size of each spare, in bytes. |
syncmirror_pool |
string |
SyncMirror spare pool. |
usable |
integer |
Total number of usable spares in the bucket. The usable count for each class of spares does not include reserved spare capacity recommended by ONTAP best practices.
returned_error
arguments |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
