Retrieve SnapLock audit logs
GET /storage/snaplock/audit-logs/{svm.uuid}
Introduced In: 9.7
Retrieves SnapLock logs for the specified SVM.
Related ONTAP commands
snaplock log show
Learn more
svm.uuid  |
string  |
path  |
True  |
SVM UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
log_archive  |
log_files  |
array[snaplock_log_file]  |
log_volume  |
svm  |
      "href": "/api/resourcelink"
  "log_archive": {
    "base_name": "string",
    "expiry_time": "2058-06-04T19:00:00Z",
    "path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
    "size": 20000
  "log_files": [
      "size": 20000
  "log_volume": {
    "max_log_size": 20971520,
    "retention_period": "P30M",
    "volume": {
      "name": "volume1",
  "svm": {
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
log_archive
_links  |
archive  |
boolean  |
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files.  |
base_name  |
string  |
Base name of log file  |
expiry_time  |
string  |
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time.  |
path  |
string  |
Absolute path of the log file in the volume  |
size  |
integer  |
Size of the log file in bytes  |
snaplock_log_file
_links  |
archive  |
boolean  |
base_name  |
string  |
expiry_time  |
string  |
path  |
string  |
size  |
integer  |
volume
_links  |
name  |
string  |
The name of the volume.  |
uuid  |
string  |
snaplock_log_volume
_links  |
max_log_size  |
integer  |
Maximum size of log file in bytes  |
retention_period  |
string  |
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "P  |
volume  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
