Retrieve SnapLock audit logs
Retrieves SnapLock audit logs to access and review the logs associated with a specific Storage Virtual Machine (SVM). Use this endpoint when you need to monitor or analyze SnapLock activities for compliance or auditing purposes.
HTTP method and endpoint
GET /storage/snaplock/audit-logs/{svm.uuid}
Introduced in
ONTAP 9.7
Usage notes
Retrieves SnapLock logs for the specified SVM.
Related ONTAP commands
snaplock log show
Learn more
svm.uuid |
string |
path |
True |
SVM UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
log_archive |
log_files |
array[snaplock_log_file] |
log_volume |
svm |
"href": "/api/resourcelink"
"log_archive": {
"base_name": "string"
"log_files": [
"base_name": "string",
"expiry_time": "2058-06-04 19:00:00 +0000",
"path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
"size": 20000
"log_volume": {
"max_log_size": 20971520,
"retention_period": "P30M",
"volume": {
"name": "volume1",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
log_archive
_links |
archive |
boolean |
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files. |
base_name |
string |
Base name of log archive |
snaplock_log_file
_links |
base_name |
string |
Base name of log file |
expiry_time |
string |
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time. |
path |
string |
Absolute path of the log file in the volume |
size |
integer |
Size of the log file in bytes |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
snaplock_log_volume
_links |
max_log_size |
integer |
Maximum size of log file in bytes |
retention_period |
string |
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "P |
volume |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
