REST API reference
Retrieve SnapLock audit logs
GET /storage/snaplock/audit-logs/{svm.uuid}
Introduced In: 9.7
Retrieves SnapLock logs for the specified SVM.
  • snaplock log show
svm.uuid
string
path
True
SVM UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
log_archive
log_archive
log_files
array[snaplock_log_file]
log_volume
snaplock_log_volume
svm
svm
      "href": "/api/resourcelink"
  "log_archive": {
    "base_name": "string"
  "log_files": [
      "base_name": "string",
      "expiry_time": "2058-06-04 15:00:00 -0400",
      "path": "/snaplock_log/system_logs/20180822_005947_GMT-present",
      "size": 20000
  "log_volume": {
    "max_log_size": 20971520,
    "retention_period": "P30M",
    "volume": {
      "name": "volume1",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
log_archive
_links
_links
archive
boolean
Archive the specified SnapLock log file for the given base_name, and create a new log file. If base_name is not mentioned, archive all log files.
base_name
string
Base name of log archive
snaplock_log_file
_links
_links
base_name
string
Base name of log file
expiry_time
string
Expiry time of the log file in date-time format. Value '9999-12-31T00:00:00Z' indicates infinite expiry time.
path
string
Absolute path of the log file in the volume
size
integer
Size of the log file in bytes
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
snaplock_log_volume
_links
_links
max_log_size
integer
Maximum size of log file in bytes
retention_period
string
Specifies the default log record retention period. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, minutes and seconds. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. A duration in hours, minutes and seconds is represented by "PTH", "PTM", and "PTS" respectively. The period string must contain only a single time element i.e. either years, months, days, hours, minutes or seconds. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the string "infinite".
volume
volume
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
