Retrieve a core dump
GET /support/coredump/coredumps/{node.uuid}/{name}
Introduced In: 9.10
Retrieves a specific core dump.
Related ONTAP commands
system node coredump show
node.uuid  |
string  |
path  |
True  |
Node UUID  |
name  |
string  |
path  |
True  |
Core name  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
is_partial  |
boolean  |
Specifies whether or not the core is a partial core. Applicable only to kernel core dump type.  |
is_saved  |
boolean  |
Specifies whether or not the core file is saved.  |
md5_data_checksum  |
string  |
MD5 checksum of the compressed data of core. Applicable only to kernel core dump type.  |
name  |
string  |
Core name  |
node  |
panic_time  |
string  |
Time of panic that generated the core.  |
size  |
integer  |
Size of core, in bytes. Applicable only to kernel core dump type.  |
type  |
string  |
Core type, kernel or application  |
      "href": "/api/resourcelink"
  "md5_data_checksum": "5118488cc5065e33a16986001b1ffa48",
  "name": "core.4136886413.2021-03-01.22_09_11.nz",
  "node": {
    "name": "node1",
  "panic_time": "2021-03-01T18:09:11-04:00",
  "size": 1161629804,
  "type": "kernel"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
node
_links  |
name  |
string  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
