REST API reference
Retrieve a core dump
Retrieves a specific core dump to access diagnostic data for troubleshooting purposes.
HTTP method and endpoint
GET /support/coredump/coredumps/{node.uuid}/{name}
Introduced in
ONTAP 9.10
  • system node coredump show
node.uuid
string
path
True
Node UUID
name
string
path
True
Core name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
is_partial
boolean
Specifies whether or not the core is a partial core. Applicable only to kernel core dump type.
is_saved
boolean
Specifies whether or not the core file is saved.
md5_data_checksum
string
MD5 checksum of the compressed data of core. Applicable only to kernel core dump type.
name
string
Core name
node
node
panic_time
string
Time of panic that generated the core.
size
integer
Size of core, in bytes. Applicable only to kernel core dump type.
type
string
Core type, kernel or application
      "href": "/api/resourcelink"
  "md5_data_checksum": "5118488cc5065e33a16986001b1ffa48",
  "name": "core.4136886413.2021-03-01.22_09_11.nz",
  "node": {
    "name": "node1",
  "panic_time": "2021-03-01 22:09:11 +0000",
  "size": 1161629804,
  "type": "kernel"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
node
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
