Retrieve a core dump
Retrieves a specific core dump to access diagnostic data for troubleshooting purposes.
HTTP method and endpoint
GET /support/coredump/coredumps/{node.uuid}/{name}
Introduced in
ONTAP 9.10
Related ONTAP commands
system node coredump show
node.uuid |
string |
path |
True |
Node UUID |
name |
string |
path |
True |
Core name |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
is_partial |
boolean |
Specifies whether or not the core is a partial core. Applicable only to kernel core dump type. |
is_saved |
boolean |
Specifies whether or not the core file is saved. |
md5_data_checksum |
string |
MD5 checksum of the compressed data of core. Applicable only to kernel core dump type. |
name |
string |
Core name |
node |
panic_time |
string |
Time of panic that generated the core. |
size |
integer |
Size of core, in bytes. Applicable only to kernel core dump type. |
type |
string |
Core type, kernel or application |
"href": "/api/resourcelink"
"md5_data_checksum": "5118488cc5065e33a16986001b1ffa48",
"name": "core.4136886413.2021-03-01.22_09_11.nz",
"node": {
"name": "node1",
"panic_time": "2021-03-01 17:09:11 -0500",
"size": 1161629804,
"type": "kernel"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
node
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
