REST API reference
Retrieve SNMP traphosts
Retrieves a list of SNMP traphosts, including the SNMP users configured for those traphosts. This helps you manage and monitor SNMP configurations effectively.
HTTP method and endpoint
GET /support/snmp/traphosts
Introduced in
ONTAP 9.7
Usage notes
Retrieves the list of SNMP traphosts along with the SNMP users configured for those traphosts.
  • system snmp traphost show
ip_address
string
query
False
Filter by ip_address
host
string
query
False
Filter by host
user.name
string
query
False
Filter by user.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records.
records
array[snmp_traphost]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "host": "traphost.example.com",
      "ip_address": "10.10.10.7",
      "user": {
        "name": "snmpv3user3"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
user
Optional SNMP user parameter. For an SNMPv3 traphost, this property refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this property refers to an SNMP community.
_links
_links
name
string
Optional SNMPv1/SNMPv2c or SNMPv3 user name. For an SNMPv3 traphost, this object refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this object refers to an SNMP community. For an SNMPv3 traphost, this object is mandatory and refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, ONTAP automatically uses "public", if the same is configured, or any other configured community as user. So, for an SNMPv1 or SNMPv2c traphost, this property should not be provided in the "POST" method. However, the configured community for the SNMPv1/SNMPv2c traphost is returned by the "GET" method.
  • example: snmpv3user3
  • Introduced in: 9.7
snmp_traphost
SNMP manager or host machine that receives SNMP traps from ONTAP.
_links
_links
host
string
Fully qualified domain name (FQDN), IPv4 address or IPv6 address of SNMP traphost.
ip_address
string
IPv4 or IPv6 address
user
user
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
