Retrieve SNMP traphosts
Retrieves the list of SNMP traphosts to view the configured SNMP users for those traphosts, helping you manage SNMP notifications effectively.
HTTP method and endpoint
GET /support/snmp/traphosts
Introduced in
ONTAP 9.7
Usage notes
Retrieves the list of SNMP traphosts along with the SNMP users configured for those traphosts.
Related ONTAP commands
system snmp traphost show
Learn more
host |
string |
query |
False |
Filter by host |
ip_address |
string |
query |
False |
Filter by ip_address |
user.name |
string |
query |
False |
Filter by user.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[snmp_traphost] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"host": "traphost.example.com",
"ip_address": "10.10.10.7",
"user": {
"name": "snmpv3user3"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
user
Optional SNMP user parameter. For an SNMPv3 traphost, this property refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this property refers to an SNMP community.
_links |
name |
string |
Optional SNMPv1/SNMPv2c or SNMPv3 user name. For an SNMPv3 traphost, this object refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this object refers to an SNMP community. For an SNMPv3 traphost, this object is mandatory and refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, ONTAP automatically uses "public", if the same is configured, or any other configured community as user. So, for an SNMPv1 or SNMPv2c traphost, this property should not be provided in the "POST" method. However, the configured community for the SNMPv1/SNMPv2c traphost is returned by the "GET" method.
snmp_traphost
SNMP manager or host machine that receives SNMP traps from ONTAP.
_links |
host |
string |
Fully qualified domain name (FQDN), IPv4 address or IPv6 address of SNMP traphost. |
ip_address |
string |
IPv4 or IPv6 address |
user |
Optional SNMP user parameter. For an SNMPv3 traphost, this property refers to an SNMPv3 or User-based Security Model (USM) user. For an SNMPv1 or SNMPv2c traphost, this property refers to an SNMP community. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
