REST API reference
Manage local mapping for hostnames
Overview
Displays and manages local mapping for hostnames.
Retrieving all hosts table entries
The local-hosts GET endpoint to retrieve all hosts table entries.
Retrieving all the fields of all hosts table entries.
# The API:
GET /api/name-services/local-hosts
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/local-hosts?return_records=true&return_timeout=15&fields=*" -H "accept: application/hal+json"
# The response:
 "records": [
  "owner": {
  "uuid": "6cdf045c-87ae-11eb-a56a-0050568e0287",
  "name": "svm1",
     "href": "/api/svm/svms/6cdf045c-87ae-11eb-a56a-0050568e0287"
  "address": "1.1.1.1",
  "hostname": "host.sales.foo.com",
  "aliases": [
          "host1.sales.foo.com",
          "host2.sakes.foo.com"
   "href": "/api/name-services/local-hosts/6cdf045c-87ae-11eb-a56a-0050568e0287/1.1.1.1"
  "owner": {
  "uuid": "9d080552-7bff-11eb-a56a-0050568e0287",
  "name": "svm2",
   "href": "/api/svm/svms/9d080552-7bff-11eb-a56a-0050568e0287"
  "address": "2.2.2.2",
  "hostname": "samplehost2",
  "href": "/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/2.2.2.2"
  "num_records": 2,
  "href": "/api/name-services/local-hosts?return_records=true&return_timeout=15&fields=*"
Retrieving the hosts table entry of a given svm and address(ipv4/ipv6).
# The API:
GET /api/name-services/local-hosts/{owner.uuid}/{address}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/3.3.3.3" -H "accept: aplication/hal+json"
# The response:
 "owner": {
 "name": "svm1",
 "address": "3.3.3.3",
 "hostname": "samplehost3",
 "aliases": [
 "href": "/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/3.3.3.3"
Creating a hosts table entry
The local-hosts POST endpoint creates a new hosts table entry.
Creating a hosts table entry with all fields.
# The API:
POST /api/name-services/local-hosts
# The call:
curl -X POST "https://<mgmt-ip>/api/name-services/local-hosts?return_records=false" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"address\": \"3.3.3.3\", \"aliases\": [ \"host1.sales.foo.com\", \"host2.sakes.foo.com\" ], \"hostname\":\"samplehost3\", \"owner\": { \"name\": \"svm2\", \"uuid\": \"9d080552-7bff-11eb-a56a-0050568e0287\" }}"
Creating a hosts table entry with only required fields.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/name-services/local-hosts?return_records=false" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"address\": \"123.123.123.12\", \"hostname\": \"host.sales.foo.com\", \"owner\": { \"name\": \"svm2\", \"uuid\": \"9d080552-7bff-11eb-a56a-0050568e0287\" }}"
Updating a hosts table entry
The local-hosts PATCH endpoint updates an existing hosts table entry.
Example
Updating aliases and hostname of a given svm and address(ipv4/ipv6).
# The API:
PATCH /api/name-services/local-hosts/{owner.uuid}/{address}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/123.123.123.123" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aliases\": [ \"host1.sales.foo.com\", \"host2.sakes.foo.com\" ], \"hostname\": \"host.sales.foo.com\"}"
Deleting a hosts table entry
The local-hosts DELETE endpoint deletes an existing hosts table entry.
Example
Deleting the hosts table entry of a given svm and address(ipv4/ipv6).
# The API:
DELETE /api/name-services/local-hosts/{owner.uuid}/{address}
#The call:
curl -X DELETE "https://<mgmt-ip>/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/1.1.1.1" -H "accept: application/json"
