REST API reference
Manage local mapping for hostnames
Use these endpoints to display and manage local mapping for hostnames within your system. These operations are essential for handling the hosts table, whether retrieving, creating, updating, or deleting entries.
Overview
Displays and manages local mapping for hostnames.
Retrieving all hosts table entries
The local-hosts GET endpoint to retrieve all hosts table entries.
Retrieving all the fields of all hosts table entries.
# The API:
GET /api/name-services/local-hosts
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/local-hosts?return_records=true&return_timeout=15&fields=*" -H "accept: application/hal+json"
# The response:
 "records": [
  "owner": {
  "uuid": "6cdf045c-87ae-11eb-a56a-0050568e0287",
  "name": "svm1",
     "href": "/api/svm/svms/6cdf045c-87ae-11eb-a56a-0050568e0287"
  "address": "1.1.1.1",
  "hostname": "host.sales.foo.com",
  "aliases": [
          "host1.sales.foo.com",
          "host2.sakes.foo.com"
   "href": "/api/name-services/local-hosts/6cdf045c-87ae-11eb-a56a-0050568e0287/1.1.1.1"
  "owner": {
  "uuid": "9d080552-7bff-11eb-a56a-0050568e0287",
  "name": "svm2",
   "href": "/api/svm/svms/9d080552-7bff-11eb-a56a-0050568e0287"
  "address": "2.2.2.2",
  "hostname": "samplehost2",
  "href": "/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/2.2.2.2"
  "num_records": 2,
  "href": "/api/name-services/local-hosts?return_records=true&return_timeout=15&fields=*"
Retrieving the hosts table entry of a given svm and address(ipv4/ipv6).
# The API:
GET /api/name-services/local-hosts/{owner.uuid}/{address}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/3.3.3.3" -H "accept: application/hal+json"
# The response:
 "owner": {
 "name": "svm1",
 "address": "3.3.3.3",
 "hostname": "samplehost3",
 "aliases": [
 "href": "/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/3.3.3.3"
Creating a hosts table entry
The local-hosts POST endpoint creates a new hosts table entry.
Creating a hosts table entry with all fields.
# The API:
POST /api/name-services/local-hosts
# The call:
curl -X POST "https://<mgmt-ip>/api/name-services/local-hosts?return_records=false" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"address\": \"3.3.3.3\", \"aliases\": [ \"host1.sales.foo.com\", \"host2.sakes.foo.com\" ], \"hostname\":\"samplehost3\", \"owner\": { \"name\": \"svm2\", \"uuid\": \"9d080552-7bff-11eb-a56a-0050568e0287\" }}"
Creating a hosts table entry with only required fields.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/name-services/local-hosts?return_records=false" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"address\": \"123.123.123.12\", \"hostname\": \"host.sales.foo.com\", \"owner\": { \"name\": \"svm2\", \"uuid\": \"9d080552-7bff-11eb-a56a-0050568e0287\" }}"
Updating a hosts table entry
The local-hosts PATCH endpoint updates an existing hosts table entry.
Example
Updating aliases and hostname of a given svm and address(ipv4/ipv6).
# The API:
PATCH /api/name-services/local-hosts/{owner.uuid}/{address}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/123.123.123.123" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aliases\": [ \"host1.sales.foo.com\", \"host2.sakes.foo.com\" ], \"hostname\": \"host.sales.foo.com\"}"
Deleting a hosts table entry
The local-hosts DELETE endpoint deletes an existing hosts table entry.
Example
Deleting the hosts table entry of a given svm and address(ipv4/ipv6).
# The API:
DELETE /api/name-services/local-hosts/{owner.uuid}/{address}
#The call:
curl -X DELETE "https://<mgmt-ip>/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/1.1.1.1" -H "accept: application/json"
