REST API reference
Manage local mapping for hostnames
Manage local hostname mappings to display and modify entries in the hosts table. Use these endpoints to retrieve, create, update, and delete local-hosts records for efficient hostname resolution within your ONTAP environment.
Overview
Displays and manages local mapping for hostnames.
Retrieving all hosts table entries
The local-hosts GET endpoint to retrieve all hosts table entries.
Retrieving all the fields of all hosts table entries.
# The API:
GET /api/name-services/local-hosts
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/local-hosts?return_records=true&return_timeout=15&fields=*" -H "accept: application/hal+json"
# The response:
 "records": [
  "owner": {
  "uuid": "6cdf045c-87ae-11eb-a56a-0050568e0287",
  "name": "svm1",
     "href": "/api/svm/svms/6cdf045c-87ae-11eb-a56a-0050568e0287"
  "address": "1.1.1.1",
  "hostname": "host.sales.foo.com",
  "aliases": [
          "host1.sales.foo.com",
          "host2.sakes.foo.com"
   "href": "/api/name-services/local-hosts/6cdf045c-87ae-11eb-a56a-0050568e0287/1.1.1.1"
  "owner": {
  "uuid": "9d080552-7bff-11eb-a56a-0050568e0287",
  "name": "svm2",
   "href": "/api/svm/svms/9d080552-7bff-11eb-a56a-0050568e0287"
  "address": "2.2.2.2",
  "hostname": "samplehost2",
  "href": "/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/2.2.2.2"
  "num_records": 2,
  "href": "/api/name-services/local-hosts?return_records=true&return_timeout=15&fields=*"
Retrieving the hosts table entry of a given svm and address(ipv4/ipv6).
# The API:
GET /api/name-services/local-hosts/{owner.uuid}/{address}
# The call:
curl -X GET "https://<mgmt-ip>/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/3.3.3.3" -H "accept: application/hal+json"
# The response:
 "owner": {
 "name": "svm1",
 "address": "3.3.3.3",
 "hostname": "samplehost3",
 "aliases": [
 "href": "/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/3.3.3.3"
Creating a hosts table entry
The local-hosts POST endpoint creates a new hosts table entry.
Creating a hosts table entry with all fields.
# The API:
POST /api/name-services/local-hosts
# The call:
curl -X POST "https://<mgmt-ip>/api/name-services/local-hosts?return_records=false" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"address\": \"3.3.3.3\", \"aliases\": [ \"host1.sales.foo.com\", \"host2.sakes.foo.com\" ], \"hostname\":\"samplehost3\", \"owner\": { \"name\": \"svm2\", \"uuid\": \"9d080552-7bff-11eb-a56a-0050568e0287\" }}"
Creating a hosts table entry with only required fields.
# The API:
# The call:
curl -X POST "https://<mgmt-ip>/api/name-services/local-hosts?return_records=false" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"address\": \"123.123.123.12\", \"hostname\": \"host.sales.foo.com\", \"owner\": { \"name\": \"svm2\", \"uuid\": \"9d080552-7bff-11eb-a56a-0050568e0287\" }}"
Updating a hosts table entry
The local-hosts PATCH endpoint updates an existing hosts table entry.
Example
Updating aliases and hostname of a given svm and address(ipv4/ipv6).
# The API:
PATCH /api/name-services/local-hosts/{owner.uuid}/{address}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/123.123.123.123" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"aliases\": [ \"host1.sales.foo.com\", \"host2.sakes.foo.com\" ], \"hostname\": \"host.sales.foo.com\"}"
Deleting a hosts table entry
The local-hosts DELETE endpoint deletes an existing hosts table entry.
Example
Deleting the hosts table entry of a given svm and address(ipv4/ipv6).
# The API:
DELETE /api/name-services/local-hosts/{owner.uuid}/{address}
#The call:
curl -X DELETE "https://<mgmt-ip>/api/name-services/local-hosts/9d080552-7bff-11eb-a56a-0050568e0287/1.1.1.1" -H "accept: application/json"
