REST API reference
Update the license manager configuration
Updates the license manager configuration to modify existing licensing settings.
HTTP method and endpoint
PATCH /cluster/licensing/license-managers/{uuid}
Introduced in
ONTAP 9.8
  • system license license-manager modify
uuid
string
path
True
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
default
boolean
Flag that indicates whether it's the default license manager instance used by the cluster.' When a capacity pool is created and if the license manager field is omitted, it is assumed that the license of the capacity pool is installed on the default license manager instance.
uri
uri
License manager URI.
uuid
string
Example request
  "uri": {
    "host": "10.1.1.1"
  "uuid": "4ea7a442-86d1-11e0-ae1c-112233445566"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
1115532
The requested update to the license manager information failed.
errors
array[error]
Example error
  "errors": [
      "arguments": [
          "code": "string",
          "message": "string"
      "code": "4",
      "target": "uuid"
string
uri
host
string
License manager host name, IPv4 or IPv6 address.
license_manager
Information on a license manager instance associated with the cluster.
default
boolean
uri
uri
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
