Update license manager configuration
Updates the license manager configuration to modify settings as needed for managing software licenses effectively.
HTTP method and endpoint
PATCH /cluster/licensing/license-managers/{uuid}
Introduced in
ONTAP 9.8
Learn more
Related ONTAP commands
system license license-manager modify
uuid |
string |
path |
True |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
default |
boolean |
Flag that indicates whether it's the default license manager instance used by the cluster.' When a capacity pool is created and if the license manager field is omitted, it is assumed that the license of the capacity pool is installed on the default license manager instance. |
uri |
License manager URI. |
uuid |
string |
Example request
"uri": {
"host": "10.1.1.1"
"uuid": "4ea7a442-86d1-11e0-ae1c-112233445566"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1115532 |
The requested update to the license manager information failed. |
errors |
array[error] |
Example error
"errors": [
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
uri
host |
string |
License manager host name, IPv4 or IPv6 address. |
license_manager
Information on a license manager instance associated with the cluster.
default |
boolean |
uri |
uuid |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
