Update the license manager configuration
PATCH /cluster/licensing/license-managers/{uuid}
Introduced In: 9.8
Updates the license manager configuration.
Learn more
Related ONTAP commands
system license license-manager modify
uuid  |
string  |
path  |
True  |
return_timeout  |
integer  |
query  |
False  |
Request Body
| Name | Type | Description |
default  |
boolean  |
Flag that indicates whether it's the default license manager instance used by the cluster.' When a capacity pool is created and if the license manager field is omitted, it is assumed that the license of the capacity pool is installed on the default license manager instance.  |
uri  |
License manager URI.  |
uuid  |
string  |
Example request
  "uri": {
    "host": "10.1.1.1"
  "uuid": "4ea7a442-86d1-11e0-ae1c-112233445566"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1115532  |
The requested update to the license manager information failed.  |
errors  |
array[returned_error]  |
Example error
  "errors": [
      "arguments": [
          "code": "string",
          "message": "string"
      "code": "4",
      "target": "uuid"
href  |
string  |
self_link
uri
host  |
string  |
License manager host name, IPv4 or IPv6 address.  |
license_manager
Information on a license manager instance associated with the cluster.
default  |
boolean  |
uri  |
uuid  |
string  |
_links
job_link
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
