REST API reference
Update the web services configuration
Updates the web services configuration to modify the settings that control web-based interactions with your system.
HTTP method and endpoint
PATCH /cluster/web
Introduced in
ONTAP 9.10
  • system services web modify
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
certificate
certificate
Certificate used by cluster and node management interfaces for TLS connection requests.
client_enabled
boolean
Indicates whether client authentication is enabled.
csrf
csrf
enabled
boolean
Indicates whether remote clients can connect to the web services.
http_enabled
boolean
Indicates whether HTTP is enabled.
http_port
integer
HTTP port for cluster-level web services.
https_port
integer
HTTPS port for cluster-level web services.
ocsp_enabled
boolean
Indicates whether online certificate status protocol verification is enabled.
per_address_limit
integer
The number of connections that can be processed concurrently from the same remote address.
state
string
State of the cluster-level web services.
wait_queue_capacity
integer
The maximum size of the wait queue for connections exceeding the per-address-limit.
Example request
  "certificate": {
    "name": "cert1",
  "csrf": {
    "token": {
      "concurrent_limit": 120
  "per_address_limit": 42,
  "state": "string"
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
9830406
Reconfiguration of the web services failed.
9830407
The web services failed to restart.
9830408
Reconfiguration and/or restart of the web services failed.
9830442
Client authentication cannot be enabled without a client ca certificate.
9830463
The cluster must be fully upgraded before modifying this resource.
9830464
HTTP cannot be enabled when FIPS is also enabled.
9830483
The CSRF token timeout is invalid.
9830484
The maximum concurrent CSRF token count cannot be lower than 100.
9830485
The CSRF idle timeout cannot be greater than the CSRF absolute timeout.
9830486
CSRF requires an effective cluster version of 9.7 or later.
9830487
The HTTP and HTTPS ports must not have the same value.
9830488
The certificate is not a "server" certificate.
9830489
The certificate does not exist for the given SVM.
string
certificate
name
string
Certificate name
uuid
string
Certificate UUID
token
concurrent_limit
integer
Maximum number of concurrent CSRF tokens.
idle_timeout
integer
Time for which an unused CSRF token is retained, in seconds.
max_timeout
integer
Time for which an unused CSRF token, regardless of usage is retained, in seconds.
csrf
protection_enabled
boolean
Indicates whether CSRF protection is enabled.
token
token
web
certificate
certificate
client_enabled
boolean
csrf
csrf
enabled
boolean
http_enabled
boolean
http_port
integer
https_port
integer
ocsp_enabled
boolean
per_address_limit
integer
state
string
wait_queue_capacity
integer
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
