Update the web services configuration
Updates the web services configuration to modify settings and manage how web services operate within your system. This endpoint is useful when you need to align web service parameters with specific network or security requirements.
HTTP method and endpoint
PATCH /cluster/web
Introduced in
ONTAP 9.10
Related ONTAP commands
system services web modify
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
certificate |
Certificate used by cluster and node management interfaces for TLS connection requests. |
client_enabled |
boolean |
Indicates whether client authentication is enabled. |
csrf |
enabled |
boolean |
Indicates whether remote clients can connect to the web services. |
http_enabled |
boolean |
Indicates whether HTTP is enabled. |
http_port |
integer |
HTTP port for cluster-level web services. |
https_port |
integer |
HTTPS port for cluster-level web services. |
ocsp_enabled |
boolean |
Indicates whether online certificate status protocol verification is enabled. |
per_address_limit |
integer |
The number of connections that can be processed concurrently from the same remote address. |
state |
string |
State of the cluster-level web services. |
wait_queue_capacity |
integer |
The maximum size of the wait queue for connections exceeding the per-address-limit. |
Example request
"certificate": {
"name": "cert1",
"csrf": {
"token": {
"concurrent_limit": 120
"per_address_limit": 42,
"state": "string"
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9830406 |
Reconfiguration of the web services failed. |
9830407 |
The web services failed to restart. |
9830408 |
Reconfiguration and/or restart of the web services failed. |
9830442 |
Client authentication cannot be enabled without a client ca certificate. |
9830463 |
The cluster must be fully upgraded before modifying this resource. |
9830464 |
HTTP cannot be enabled when FIPS is also enabled. |
9830483 |
The CSRF token timeout is invalid. |
9830484 |
The maximum concurrent CSRF token count cannot be lower than 100. |
9830485 |
The CSRF idle timeout cannot be greater than the CSRF absolute timeout. |
9830486 |
CSRF requires an effective cluster version of 9.7 or later. |
9830487 |
The HTTP and HTTPS ports must not have the same value. |
9830488 |
The certificate is not a "server" certificate. |
9830489 |
The certificate does not exist for the given SVM. |
href |
string |
_links
certificate
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
token
concurrent_limit |
integer |
Maximum number of concurrent CSRF tokens. |
idle_timeout |
integer |
Time for which an unused CSRF token is retained, in seconds. |
max_timeout |
integer |
Time for which an unused CSRF token, regardless of usage is retained, in seconds. |
csrf
protection_enabled |
boolean |
Indicates whether CSRF protection is enabled. |
token |
web
certificate |
client_enabled |
boolean |
csrf |
enabled |
boolean |
http_enabled |
boolean |
http_port |
integer |
https_port |
integer |
ocsp_enabled |
boolean |
per_address_limit |
integer |
state |
string |
integer |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
