Update the web services configuration
Updates the web services configuration to adjust settings for secure and efficient communication with ONTAP systems.
HTTP method and endpoint
PATCH /cluster/web
Introduced in
ONTAP 9.10
Related ONTAP commands
system services web modify -
security ssl modify
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
certificate |
Certificate used by cluster and node management interfaces for TLS connection requests. |
client_enabled |
boolean |
Indicates whether client authentication is enabled. |
csrf |
enabled |
boolean |
Indicates whether remote clients can connect to the web services. |
hsts |
http_enabled |
boolean |
Indicates whether HTTP is enabled. |
http_port |
integer |
HTTP port for cluster-level web services. |
https_port |
integer |
HTTPS port for cluster-level web services. |
ocsp_enabled |
boolean |
Indicates whether online certificate status protocol verification is enabled. |
per_address_limit |
integer |
The number of connections that can be processed concurrently from the same remote address. |
state |
string |
State of the cluster-level web services. |
wait_queue_capacity |
integer |
The maximum size of the wait queue for connections exceeding the per-address-limit. |
Example request
"certificate": {
"name": "cert1",
"csrf": {
"token": {
"concurrent_limit": 120,
"idle_timeout": 200,
"max_timeout": 1200
"hsts": {
"max_age": 31536000
"per_address_limit": 42,
"state": "string"
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9830406 |
Reconfiguration of the web services failed. |
9830407 |
The web services failed to restart. |
9830408 |
Reconfiguration and/or restart of the web services failed. |
9830442 |
Client authentication cannot be enabled without a client ca certificate. |
9830463 |
The cluster must be fully upgraded before modifying this resource. |
9830464 |
HTTP cannot be enabled when FIPS is also enabled. |
9830483 |
The CSRF token timeout is invalid. |
9830484 |
The maximum concurrent CSRF token count cannot be lower than 100. |
9830485 |
The CSRF idle timeout cannot be greater than the CSRF absolute timeout. |
9830486 |
CSRF requires an effective cluster version of 9.7 or later. |
9830487 |
The HTTP and HTTPS ports must not have the same value. |
9830488 |
The certificate is not a "server" certificate. |
9830489 |
The certificate does not exist for the given SVM. |
href |
string |
_links
certificate
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
token
concurrent_limit |
integer |
Maximum number of concurrent CSRF tokens. |
idle_timeout |
integer |
Time for which an unused CSRF token is retained, in seconds. |
max_timeout |
integer |
Time for which an unused CSRF token, regardless of usage is retained, in seconds. |
csrf
protection_enabled |
boolean |
Indicates whether CSRF protection is enabled. |
token |
hsts
enabled |
boolean |
Indicates whether HTTP Strict Transport Security (HSTS) is enabled. |
max_age |
integer |
HTTPS Strict Transport Security (HSTS) max-age value in seconds. The maximum time, in seconds, that the browser should remember that a site is only to be accessed using HTTPS. |
web
certificate |
client_enabled |
boolean |
csrf |
enabled |
boolean |
hsts |
http_enabled |
boolean |
http_port |
integer |
https_port |
integer |
ocsp_enabled |
boolean |
per_address_limit |
integer |
state |
string |
integer |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
