Update the retention period of an EBR policy
Updates the retention period of an Event Based Retention (EBR) policy to adjust how long events are retained according to your organization's data management requirements.
HTTP method and endpoint
PATCH /storage/snaplock/event-retention/policies/{policy.name}
Introduced in
ONTAP 9.7
Related ONTAP commands
snaplock event-retention policy modify
Example
Updates the retention period of an EBR policy "policy_name":
PATCH "/api/storage/snaplock/event-retention/policies/" '{"name": "policy_name","retention_period": "P20Y"}'
policy.name |
string |
path |
True |
Name of the retention policy |
Request Body
| Name | Type | Description |
name |
string |
Specifies the EBR policy name |
retention_period |
string |
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "P |
svm |
Example request
"name": "string",
"retention_period": "P30M",
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default, Error
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
snaplock_retention_policy
name |
string |
retention_period |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
