REST API reference
Update the retention period of an EBR policy
Updates the retention period for an Event Based Retention (EBR) policy to adjust how long data is retained based on events. Use this when you need to modify retention settings to meet compliance or data management requirements.
HTTP method and endpoint
PATCH /storage/snaplock/event-retention/policies/{policy.name}
Introduced in
ONTAP 9.7
Usage notes
Updates the retention period of an Event Based Retention (EBR) policy.
  • snaplock event-retention policy modify
Example
Updates the retention period of an EBR policy "policy_name":
PATCH "/api/storage/snaplock/event-retention/policies/{policy.name}" '{"retention_period": "P20Y"}'
policy.name
string
path
True
Name of the retention policy
Request Body
Name Type Description
retention_period
string
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. Similarly, a duration in hours, minutes is represented by "PTH", "PTM" respectively. The period string must contain only a single time element i.e. either years, months, days, hours or minutes. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the strings "infinite" and "unspecified".
svm
svm
Example request
  "retention_period": "P30M",
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
918253
Incorrect format for the retention period, duration must be in the ISO-8601 format or infinite or unspecified.
13763280
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation.
string
svm
name
string
uuid
string
snaplock_retention_policy
retention_period
string
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
