Update the retention period of an EBR policy
PATCH /storage/snaplock/event-retention/policies/{policy.name}
Introduced In: 9.7
Updates the retention period of an Event Based Retention (EBR) policy.
Related ONTAP commands
snaplock event-retention policy modify
Example
Updates the retention period of an EBR policy "policy_name":
PATCH "/api/storage/snaplock/event-retention/policies/{policy.name}" '{"retention_period": "P20Y"}'
policy.name |
string |
path |
True |
Name of the retention policy |
Request Body
| Name | Type | Description |
retention_period |
string |
Specifies the retention period of an event based retention policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "P |
svm |
Example request
"retention_period": "P30M",
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
918253 |
Incorrect format for the retention period, duration must be in the ISO-8601 format or infinite or unspecified. |
13763280 |
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation. |
href |
string |
_links
svm
name |
string |
uuid |
string |
snaplock_retention_policy
retention_period |
string |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
