REST API reference
Updates the retention period of an event based retention (ebr) policy
example
updates the retention period of an ebr policy "policy_name": <br/>
patch "/api/storage/snaplock/event-retention/policies/" {"name": "policy_name","retention_period": "p20y"}
<br/> # learn more * [doc /storage/snaplock/event-retention/policies](#docs-snaplock-storage_snaplock_event-retention_policies)
PATCH /storage/snaplock/event-retention/policies/{policy.name}
Updates the retention period of an Event Based Retention (EBR) policy.
  • snaplock event-retention policy modify
Example
Updates the retention period of an EBR policy "policy_name":
PATCH "/api/storage/snaplock/event-retention/policies/" '{"name": "policy_name","retention_period": "P20Y"}'
policy.name
string
path
True
Name of the retention policy
Request Body
Name Type Description
_links
_links
name
string
Specifies the EBR policy name
retention_period
string
Specifies the retention period of an EBR policy. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours or minutes. A period specified for years, months and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively. For example "P10Y" represents a duration of 10 years. Similarly, a duration in hours, minutes is represented by "PTH", "PTM" respectively. The period string must contain only a single time element i.e. either years, months, days, hours or minutes. A duration which combines different periods is not supported, example "P1Y10M" is not supported. Apart from the duration specified in the ISO-8601 format, the retention period field also accepts the string "infinite".
svm
svm
Example request
      "href": "/api/resourcelink"
  "name": "string",
  "retention_period": "P30M",
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
snaplock_retention_policy
_links
_links
name
string
retention_period
string
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
