Update a volume Snapshot copy
Updates a Volume Snapshot copy to modify its properties or rename it as needed.
HTTP method and endpoint
PATCH /storage/volumes/{volume.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
snapshot modify -
snapshot rename
Learn more
volume.uuid |
string |
path |
True |
Volume UUID |
uuid |
string |
path |
True |
Snapshot copy UUID |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
A comment associated with the Snapshot copy. This is an optional attribute for POST or PATCH. |
create_time |
string |
Creation time of the Snapshot copy. It is the volume access time when the Snapshot copy was created. |
delta |
Reports the amount of space consumed between two WAFL file systems, in bytes. The two WAFL file systems should be specified in a comma-separated format using the "name" parameter. To determine the space consumed between a Snapshot copy and the Active File System, only the Snapshot copy name needs to be mentioned. |
expiry_time |
string |
The expiry time for the Snapshot copy. This is an optional attribute for POST or PATCH. Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached. |
logical_size |
integer |
Size of the logical used file system at the time the Snapshot copy is captured. |
name |
string |
Snapshot copy. Valid in POST or PATCH. |
owners |
array[string] |
provenance_volume |
reclaimable_space |
integer |
Space reclaimed when the Snapshot copy is deleted, in bytes. |
size |
integer |
Size of the active file system at the time the Snapshot copy is captured. The actual size of the Snapshot copy also includes those blocks trapped by other Snapshot copies. On a Snapshot copy deletion, the "size" amount of blocks is the maximum number of blocks available. On a Snapshot copy restore, the "afs-used size" value will match the Snapshot copy "size" value. |
snaplock_expiry_time |
string |
SnapLock expiry time for the Snapshot copy, if the Snapshot copy is taken on a SnapLock volume. A Snapshot copy is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. This option can be set during Snapshot copy POST and Snapshot copy PATCH on Snapshot copy locking enabled volumes. |
snapmirror_label |
string |
Label for SnapMirror operations |
state |
string |
State of the Snapshot copy. There are cases where some Snapshot copies are not complete. In the "partial" state, the Snapshot copy is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial Snapshot copies cannot be used for a Snapshot copy restore operation. A Snapshot copy is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a Snapshot copy is valid. |
svm |
uuid |
string |
The UUID of the Snapshot copy in the volume that uniquely identifies the Snapshot copy in that volume. |
version_uuid |
string |
The 128 bit identifier that uniquely identifies a snapshot and its logical data layout. |
volume |
Example request
"comment": "string",
"create_time": "2019-02-04T19:00:00Z",
"delta": {
"size_consumed": 0,
"time_elapsed": "string"
"expiry_time": "2019-02-04T19:00:00Z",
"logical_size": 1228800,
"name": "this_snapshot",
"owners": [
"string"
"provenance_volume": {
"uuid": "4cd8a442-86d1-11e0-ae1c-125648563413"
"size": 122880,
"snaplock_expiry_time": "2019-02-04T19:00:00Z",
"snapmirror_label": "string",
"state": "string",
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"version_uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"volume": {
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Code
| Error Code | Description |
524508 |
The Snapshot copy was not renamed because the name entered is not valid. |
542797 |
The specified file or Snapshot copy does not exist. |
1638455 |
Failed to set comment for Snapshot copy. |
1638476 |
You cannot rename a Snapshot copy created for use as a reference Snapshot copy by other jobs. |
1638477 |
User-created Snapshot copy names cannot begin with the specified prefix. |
1638518 |
The specified Snapshot copy name is invalid. |
1638522 |
Snapshot copies can only be renamed on read/write (RW) volumes. |
1638523 |
Failed to set the specified SnapMirror label for the Snapshot copy. |
1638524 |
Adding SnapMirror labels is not allowed in a mixed version cluster. |
1638539 |
Cannot determine the status of the Snapshot copy rename operation for the specified volume. |
1638554 |
Failed to set expiry time for the Snapshot copy. |
1638600 |
The Snapshot copy does not exist. |
href |
string |
_links
snapshot_delta
size_consumed |
integer |
Indicates the space that has changed between two specified WAFL file systems, in bytes. |
time_elapsed |
string |
Time elapsed between two specified WAFL file systems. |
provenance_volume
uuid |
string |
UUID for the volume that is used to identify the source volume in a mirroring relationship. When the mirroring relationship is broken, a volume's Instance UUID and Provenance UUID are made identical. An unmirrored volume's Provenance UUID is the same as its Instance UUID. This field is valid for flexible volumes only. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
volume
name |
string |
The name of the volume. |
uuid |
string |
snapshot
The Snapshot copy object represents a point in time Snapshot copy of a volume.
comment |
string |
create_time |
string |
delta |
expiry_time |
string |
logical_size |
integer |
name |
string |
owners |
array[string] |
provenance_volume |
reclaimable_space |
integer |
size |
integer |
string |
snapmirror_label |
string |
state |
string |
svm |
uuid |
string |
version_uuid |
string |
volume |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
