Update a volume snapshot
Updates a volume snapshot to change its properties or rename it as needed for your storage management tasks.
HTTP method and endpoint
PATCH /storage/volumes/{volume.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
snapshot modify -
snapshot rename
Learn more
volume.uuid |
string |
path |
True |
Volume UUID |
uuid |
string |
path |
True |
Snapshot UUID |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
A comment associated with the snapshot. This is an optional attribute for POST or PATCH. |
compress_savings |
integer |
Savings due to compression at the time the snapshot was taken in bytes. |
create_time |
string |
Creation time of the snapshot. It is the volume access time when the snapshot was created. |
dedup_savings |
integer |
Savings due to dedup at the time the snapshot was taken in bytes. |
delta |
Reports the amount of space consumed between two WAFL file systems, in bytes. The two WAFL file systems should be specified in a comma-separated format using the "name" parameter. To determine the space consumed between a snapshot and the Active File System, only the snapshot name needs to be mentioned. |
expiry_time |
string |
The expiry time for the snapshot. This is an optional attribute for POST or PATCH. Snapshots with an expiry time set are not allowed to be deleted until the retention time is reached. |
logical_size |
integer |
Size of the logical used file system at the time the snapshot is captured. |
name |
string |
Snapshot. Valid in POST or PATCH. |
owners |
array[string] |
provenance_volume |
reclaimable_space |
integer |
Space reclaimed when the snapshot is deleted, in bytes. |
size |
integer |
Size of the active file system at the time the snapshot is captured. The actual size of the snapshot also includes those blocks trapped by other snapshots. On a snapshot deletion, the "size" amount of blocks is the maximum number of blocks available. On a snapshot restore, the "afs-used size" value will match the snapshot "size" value. |
snaplock |
snaplock_expiry_time |
string |
SnapLock expiry time for the snapshot, if the snapshot is taken on a SnapLock volume. A snapshot is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. This option can be set during snapshot POST and snapshot PATCH on snapshot locking enabled volumes. This field will no longer be supported in a future release. Use snaplock.expiry_time instead. |
snapmirror_label |
string |
Label for SnapMirror operations |
state |
string |
State of the FlexGroup volume snapshot. In the "pre_conversion" state, the snapshot was created before converting the FlexVol to a FlexGroup volume. A recently created snapshot can be in the "unknown" state while the system is calculating the state. In the "partial" state, the snapshot is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial snapshots cannot be used for a snapshot restore operation. A snapshot is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a snapshot is valid. |
svm |
uuid |
string |
The UUID of the snapshot in the volume that uniquely identifies the snapshot in that volume. |
vbn0_savings |
integer |
Savings due vbn0 at the time the snapshot was taken in bytes. |
version_uuid |
string |
The 128 bit identifier that uniquely identifies a snapshot and its logical data layout. |
volume |
Example request
"comment": "string",
"compress_savings": 1131223,
"create_time": "2019-02-04 19:00:00 +0000",
"dedup_savings": 1131223,
"delta": {
"size_consumed": 0,
"time_elapsed": "string"
"expiry_time": "2019-02-04 19:00:00 +0000",
"logical_size": 1228800,
"name": "this_snapshot",
"owners": [
"string"
"provenance_volume": {
"uuid": "4cd8a442-86d1-11e0-ae1c-125648563413"
"size": "122880",
"snaplock": {
"expired": 1,
"time_until_expiry": "PT3H27M45S"
"snaplock_expiry_time": "2019-02-04 19:00:00 +0000",
"snapmirror_label": "string",
"state": "string",
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"vbn0_savings": 1131223,
"version_uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"volume": {
"name": "volume1",
Status: 202, Accepted
Status: Default
ONTAP Error Response Code
| Error Code | Description |
524508 |
The snapshot was not renamed because the name entered is not valid. |
542797 |
The specified file or snapshot does not exist. |
1638455 |
Failed to set comment for snapshot. |
1638476 |
You cannot rename a snapshot created for use as a reference snapshot by other jobs. |
1638477 |
User-created snapshot names cannot begin with the specified prefix. |
1638518 |
The specified snapshot name is invalid. |
1638522 |
Snapshots can only be renamed on read/write (RW) volumes. |
1638523 |
Failed to set the specified SnapMirror label for the snapshot. |
1638524 |
Adding SnapMirror labels is not allowed in a mixed version cluster. |
1638539 |
Cannot determine the status of the snapshot rename operation for the specified volume. |
1638554 |
Failed to set expiry time for the snapshot. |
1638600 |
The snapshot does not exist. |
1638644 |
POST, DELETE, and PATCH requests on the snapshot session endpoint are not supported on this platform. |
href |
string |
_links
snapshot_delta
size_consumed |
integer |
Indicates the space that has changed between two specified WAFL file systems, in bytes. |
time_elapsed |
string |
Time elapsed between two specified WAFL file systems. |
provenance_volume
uuid |
string |
UUID for the volume that is used to identify the source volume in a mirroring relationship. When the mirroring relationship is broken, a volume's Instance UUID and Provenance UUID are made identical. An unmirrored volume's Provenance UUID is the same as its Instance UUID. This field is valid for flexible volumes only. |
snaplock
expired |
boolean |
Indicates whether a SnapLock snapshot has expired. |
expiry_time |
string |
SnapLock expiry time for the snapshot, if the snapshot is taken on a SnapLock volume. A snapshot is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. This option can be set during snapshot POST and snapshot PATCH on snapshot locking enabled volumes. It can also be used to extend the expiry time of a locked snapshot on a SnapLock for SnapVault destination consistency-group. |
time_until_expiry |
string |
Indicates the remaining SnapLock expiry time of a locked snapshot, in seconds. This field is set only when the remaining time interval is less than 136 years. |
svm
name |
string |
uuid |
string |
volume
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
snapshot
The snapshot object represents a point in time snapshot of a volume.
comment |
string |
compress_savings |
integer |
create_time |
string |
dedup_savings |
integer |
delta |
expiry_time |
string |
logical_size |
integer |
name |
string |
owners |
array[string] |
provenance_volume |
reclaimable_space |
integer |
size |
integer |
snaplock |
string |
snapmirror_label |
string |
state |
string |
svm |
uuid |
string |
vbn0_savings |
integer |
version_uuid |
string |
volume |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
