REST API reference
Update a volume Snapshot copy
Updates a Volume Snapshot copy to reflect changes in your storage environment or to modify its attributes.
HTTP method and endpoint
PATCH /storage/volumes/{volume.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.6
  • snapshot modify
  • snapshot rename
volume.uuid
string
path
True
Volume UUID
uuid
string
path
True
Snapshot copy UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
comment
string
A comment associated with the Snapshot copy. This is an optional attribute for POST or PATCH.
create_time
string
Creation time of the Snapshot copy. It is the volume access time when the Snapshot copy was created.
delta
snapshot_delta
Reports the amount of space consumed between two WAFL file systems, in bytes. The two WAFL file systems should be specified in a comma-separated format using the "name" parameter. To determine the space consumed between a Snapshot copy and the Active File System, only the Snapshot copy name needs to be mentioned.
expiry_time
string
The expiry time for the Snapshot copy. This is an optional attribute for POST or PATCH. Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached.
logical_size
integer
Size of the logical used file system at the time the Snapshot copy is captured.
name
string
Snapshot copy. Valid in POST or PATCH.
owners
array[string]
provenance_volume
provenance_volume
reclaimable_space
integer
Space reclaimed when the Snapshot copy is deleted, in bytes.
size
integer
Size of the active file system at the time the Snapshot copy is captured. The actual size of the Snapshot copy also includes those blocks trapped by other Snapshot copies. On a Snapshot copy deletion, the "size" amount of blocks is the maximum number of blocks available. On a Snapshot copy restore, the "afs-used size" value will match the Snapshot copy "size" value.
snaplock_expiry_time
string
SnapLock expiry time for the Snapshot copy, if the Snapshot copy is taken on a SnapLock volume. A Snapshot copy is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. This option can be set during Snapshot copy POST and Snapshot copy PATCH on Snapshot copy locking enabled volumes.
snapmirror_label
string
Label for SnapMirror operations
state
string
State of the Snapshot copy. There are cases where some Snapshot copies are not complete. In the "partial" state, the Snapshot copy is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial Snapshot copies cannot be used for a Snapshot copy restore operation. A Snapshot copy is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a Snapshot copy is valid.
svm
svm
uuid
string
The UUID of the Snapshot copy in the volume that uniquely identifies the Snapshot copy in that volume.
version_uuid
string
The 128 bit identifier that uniquely identifies a snapshot and its logical data layout.
volume
volume
Example request
  "comment": "string",
  "create_time": "2019-02-04 19:00:00 +0000",
  "delta": {
    "size_consumed": 0,
    "time_elapsed": "string"
  "expiry_time": "2019-02-04 19:00:00 +0000",
  "logical_size": 1228800,
  "name": "this_snapshot",
  "owners": [
    "string"
  "provenance_volume": {
    "uuid": "4cd8a442-86d1-11e0-ae1c-125648563413"
  "size": "122880",
  "snaplock_expiry_time": "2019-02-04 19:00:00 +0000",
  "snapmirror_label": "string",
  "state": "string",
  "svm": {
    "name": "svm1",
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "version_uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "volume": {
    "name": "volume1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Code
Error Code Description
524508
The Snapshot copy was not renamed because the name entered is not valid.
542797
The specified file or Snapshot copy does not exist.
1638455
Failed to set comment for Snapshot copy.
1638476
You cannot rename a Snapshot copy created for use as a reference Snapshot copy by other jobs.
1638477
User-created Snapshot copy names cannot begin with the specified prefix.
1638518
The specified Snapshot copy name is invalid.
1638522
Snapshot copies can only be renamed on read/write (RW) volumes.
1638523
Failed to set the specified SnapMirror label for the Snapshot copy.
1638524
Adding SnapMirror labels is not allowed in a mixed version cluster.
1638539
Cannot determine the status of the Snapshot copy rename operation for the specified volume.
1638554
Failed to set expiry time for the Snapshot copy.
1638600
The Snapshot copy does not exist.
string
snapshot_delta
size_consumed
integer
Indicates the space that has changed between two specified WAFL file systems, in bytes.
time_elapsed
string
Time elapsed between two specified WAFL file systems.
provenance_volume
uuid
string
UUID for the volume that is used to identify the source volume in a mirroring relationship. When the mirroring relationship is broken, a volume's Instance UUID and Provenance UUID are made identical. An unmirrored volume's Provenance UUID is the same as its Instance UUID. This field is valid for flexible volumes only.
svm
name
string
The name of the SVM.
uuid
string
volume
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
snapshot
The Snapshot copy object represents a point in time Snapshot copy of a volume.
comment
string
create_time
string
delta
snapshot_delta
expiry_time
string
logical_size
integer
name
string
owners
array[string]
provenance_volume
provenance_volume
reclaimable_space
integer
size
integer
string
snapmirror_label
string
state
string
svm
svm
uuid
string
version_uuid
string
volume
volume
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
