REST API reference
Update an SVM peer relationship
Updates an SVM peer relationship to change its configuration or status as needed for your storage management tasks.
HTTP method and endpoint
PATCH /svm/peers/{uuid}
Introduced in
ONTAP 9.6
  • vserver peer modify
The following examples show how to update an SVM peer relationship. The input parameter 'name' refers to the local name of the peer SVM.
  1. Accepts an SVM peer relationship
 PATCH "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9" '{"state":"peered"}'
  1. Updates the local name of an SVM peer relationship
 PATCH "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9" '{"name":"vs2"}'
  1. Suspends an SVM peer relationship using force flag
 PATCH "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9" '{"state":"suspended", "force": "true"}'
Learn more
uuid
string
path
True
SVM peer relationship UUID
  • Introduced in: 9.7
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
applications
array[string]
A list of applications for an SVM peer relation.
force
boolean
Use this to suspend, resume or delete the SVM peer relationship even if the remote cluster is not accessible due to, for example, network connectivity issues.
state
string
SVM peering state. To accept a pending SVM peer request, PATCH the state to "peered". To reject a pending SVM peer request, PATCH the state to "rejected". To suspend a peered SVM peer relation, PATCH the state to "suspended". To resume a suspended SVM peer relation, PATCH the state to "peered". The states "initiated", "pending", and "initializing" are system-generated and cannot be used for PATCH.
uuid
string
SVM peer relation UUID
Example request
  "applications": [
    "snapmirror",
    "lun_copy"
  "state": "peered",
  "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error codes Description
13434889
Internal error. Wait and retry.
26345575
The specified peer cluster name and peer cluster UUID do not match.
26345576
Given peer state is invalid.
26345577
One of the following is required: applications, state, or name.
26345578
Internal error. Unable to retrieve local or peer SVM name.
26345579
The specified field is invalid.
26345581
Peer cluster name could not be retrieved or validated.
string
cluster
_links
_links
name
string
uuid
string
svm
name
string
The name of the SVM.
uuid
string
peer
Details for a peer SVM object.
cluster
cluster
svm
svm
svm
Local SVM details
name
string
uuid
string
svm_peer
An SVM peer relation object.
applications
array[string]
force
boolean
state
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
