Update an SVM peer relationship
PATCH /svm/peers/{uuid}
Introduced In: 9.6
Updates the SVM peer relationship.
Related ONTAP commands
vserver peer modify
The following examples show how to update an SVM peer relationship. The input parameter 'name' refers to the local name of the peer SVM.
Accepts an SVM peer relationship
PATCH "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9" '{"state":"peered"}'
Updates the local name of an SVM peer relationship
PATCH "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9" '{"name":"vs2"}'
Learn more
Name | Type | In | Required | Description |
uuid |
string |
path |
True |
SVM peer relationship UUID
return_timeout |
integer |
query |
False |
Request Body
Name | Type | Description |
applications |
array[string] |
A list of applications for an SVM peer relation. |
state |
string |
SVM peering state. To accept a pending SVM peer request, PATCH the state to "peered". To reject a pending SVM peer request, PATCH the state to "rejected". To suspend a peered SVM peer relation, PATCH the state to "suspended". To resume a suspended SVM peer relation, PATCH the state to "peered". The states "initiated", "pending", and "initializing" are system-generated and cannot be used for PATCH. |
uuid |
string |
SVM peer relation UUID |
Example request
"applications": [
"snapmirror",
"lun_copy"
"state": "peered",
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error codes | Description |
13434889 |
Internal error. Wait and retry. |
26345575 |
The specified peer cluster name and peer cluster UUID do not match. |
26345576 |
Given peer state is invalid. |
26345577 |
One of the following is required: applications, state, or name. |
26345578 |
Internal error. Unable to retrieve local or peer SVM name. |
26345579 |
The specified field is invalid. |
26345581 |
Peer cluster name could not be retrieved or validated. |
href |
string |
_links
cluster
name |
string |
uuid |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
peer
Details for a peer SVM object.
cluster |
svm |
svm
Local SVM details
name |
string |
uuid |
string |
svm_peer
An SVM peer relation object.
applications |
array[string] |
state |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
