Update an SVM peer relationship
Updates an SVM peer relationship, modifying its attributes to suit your configuration needs. You might use this endpoint to change the state or rename the peer relationship as part of managing your storage virtual machines.
HTTP method and endpoint
PATCH /svm/peers/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver peer modify
The following examples show how to update an SVM peer relationship. The input parameter 'name' refers to the local name of the peer SVM.
Accepts an SVM peer relationship
PATCH "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9" '{"state":"peered"}'
Updates the local name of an SVM peer relationship
PATCH "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9" '{"name":"vs2"}'
Suspends an SVM peer relationship using force flag
PATCH "/api/svm/peers/d3268a74-ee76-11e8-a9bb-005056ac6dc9" '{"state":"suspended", "force": "true"}'
Learn more
uuid |
string |
path |
True |
SVM peer relationship UUID
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
applications |
array[string] |
A list of applications for an SVM peer relationship. |
force |
boolean |
Use this to suspend, resume or delete the SVM peer relationship even if the remote cluster is not accessible due to, for example, network connectivity issues. |
name |
string |
A peer SVM alias name to avoid a name conflict on the local cluster. |
state |
string |
SVM peering state. To accept a pending SVM peer request, PATCH the state to "peered". To reject a pending SVM peer request, PATCH the state to "rejected". To suspend a peered SVM peer relationship, PATCH the state to "suspended". To resume a suspended SVM peer relationship, PATCH the state to "peered". The states "initiated", "pending", and "initializing" are system-generated and cannot be used for PATCH. |
uuid |
string |
SVM peer relationship UUID |
Example request
"applications": [
"snapmirror",
"lun_copy"
"name": "string",
"state": "peered",
"uuid": "string"
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
13434889 |
Internal error. Wait and retry. |
26345575 |
The specified peer cluster name and peer cluster UUID do not match. |
26345576 |
Given peer state is invalid. |
26345577 |
One of the following is required: applications, state, or name. |
26345578 |
Internal error. Unable to retrieve local or peer SVM name. |
26345579 |
The specified field is invalid. |
26345581 |
Peer cluster name could not be retrieved or validated. |
9896077 |
The peer relationship is in use by FlexCache. View the FlexCache relationships, delete them and retry the operation. |
9896088 |
System generated a name for the peer SVM because of a naming conflict. Use the name property to uniquely identify the peer SVM alias name. |
href |
string |
_links
cluster
name |
string |
uuid |
string |
svm
name |
string |
uuid |
string |
peer
Details for a peer SVM object.
cluster |
svm |
svm
Local SVM details
name |
string |
uuid |
string |
svm_peer
An SVM peer relationship object.
applications |
array[string] |
force |
boolean |
name |
string |
state |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
