REST API reference
Add users to a UNIX group and SVM
Adds users to a specified UNIX group and SVM. Use this to manage group memberships efficiently by appending new users to existing groups.
HTTP method and endpoint
POST /name-services/unix-groups/{svm.uuid}/{unix_group.name}/users
Introduced in
ONTAP 9.9
Important notes
  • Multiple users can be added in a single call using the "records" parameter.
  • "records" parameter must not be specified when "name" parameter is specified.
  • Specified users are appended to the existing list of users.
  • Duplicate users are ignored.
  • vserver services name-service unix-group adduser
  • vserver services name-service unix-group addusers
unix_group.name
string
path
True
UNIX group name.
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
name
string
UNIX user who belongs to the specified UNIX group and the SVM.
records
array[records]
An array of UNIX users specified to add multiple users to a UNIX group in a single API call. Not allowed when the name property is used.
skip_name_validation
boolean
Indicates whether or not the validation for the specified UNIX user names is disabled.
Example request
  "name": "string",
  "records": [
      "name": "string"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
262179
Invalid arguments in records.
3276897
The specified UNIX group does not exist in the SVM.
3277025
Maximum supported limit of UNIX group membership count reached.
3277051
Invalid characters in user name. Valid characters are 0-9, A-Z, a-z, ".", "_" and "-". Names cannot start with "-".
23724066
User name too long. Maximum supported length is 64 characters.
23724142
"records" field must not be specified when a single user is added.
23724143
SVM UUID, UNIX group name and skip-name-validation are invalid fields for "records" parameter.
string
records
name
string
svm
name
string
The name of the SVM.
uuid
string
unix_group
name
string
UNIX group name.
unix_group_users
name
string
records
array[records]
boolean
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
