Add users to a UNIX group and SVM
POST /name-services/unix-groups/{svm.uuid}/{unix_group.name}/users
Introduced In: 9.9
Adds users to the specified UNIX group and SVM.
Important notes
Multiple users can be added in a single call using the "records" parameter.
"records" parameter must not be specified when "name" parameter is specified.
Specified users are appended to the existing list of users.
Duplicate users are ignored.
Related ONTAP commands
vserver services name-service unix-group adduser
vserver services name-service unix-group addusers
Name | Type | In | Required | Description |
unix_group.name |
string |
path |
True |
UNIX group name. |
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
Name | Type | Description |
name |
string |
UNIX user who belongs to the specified UNIX group and the SVM. |
records |
array[records] |
An array of UNIX users specified to add multiple users to a UNIX group in a single API call.
Not allowed when the |
skip_name_validation |
boolean |
Indicates whether or not the validation for the specified UNIX user names is disabled. |
svm |
unix_group |
Example request
"name": "string",
"records": [
"name": "string"
"svm": {
"name": "svm1",
"unix_group": {
"name": "string"
Status: 201, Created
Headers
Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
Error Code | Description |
262179 |
Invalid arguments in records. |
3276897 |
The specified UNIX group does not exist in the SVM. |
3277025 |
Maximum supported limit of UNIX group membership count reached. |
3277051 |
Invalid characters in user name. Valid characters are 0-9, A-Z, a-z, ".", "_" and "-". Names cannot start with "-". |
23724066 |
User name too long. Maximum supported length is 64 characters. |
23724142 |
"records" field must not be specified when a single user is added. |
23724143 |
SVM UUID, UNIX group name and skip-name-validation are invalid fields for "records" parameter. |
href |
string |
_links
records
name |
string |
svm
name |
string |
uuid |
string |
unix_group
name |
string |
UNIX group name. |
unix_group_users
name |
string |
records |
array[records] |
boolean |
svm |
unix_group |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
