Add users to a UNIX group and SVM
Adds users to a specific UNIX group and Storage Virtual Machine (SVM). This operation updates the group's user list, appending new users without affecting existing entries.
HTTP method and endpoint
POST /name-services/unix-groups/{svm.uuid}/{unix_group.name}/users
Introduced in
ONTAP 9.9
Usage notes
Adds users to the specified UNIX group and SVM.
Important notes
Multiple users can be added in a single call using the "records" parameter.
"records" parameter must not be specified when "name" parameter is specified.
Specified users are appended to the existing list of users.
Duplicate users are ignored.
Related ONTAP commands
vserver services name-service unix-group adduser -
vserver services name-service unix-group addusers
unix_group.name |
string |
path |
True |
UNIX group name. |
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
name |
string |
UNIX user who belongs to the specified UNIX group and the SVM. |
records |
array[records] |
An array of UNIX users specified to add multiple users to a UNIX group in a single API call.
Not allowed when the |
skip_name_validation |
boolean |
Indicates whether or not the validation for the specified UNIX user names is disabled. |
Example request
"name": "string",
"records": [
"name": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262179 |
Invalid arguments in records. |
3276897 |
The specified UNIX group does not exist in the SVM. |
3277025 |
Maximum supported limit of UNIX group membership count reached. |
3277051 |
Invalid characters in user name. Valid characters are 0-9, A-Z, a-z, ".", "_" and "-". Names cannot start with "-". |
23724066 |
User name too long. Maximum supported length is 64 characters. |
23724142 |
"records" field must not be specified when a single user is added. |
23724143 |
SVM UUID, UNIX group name and skip-name-validation are invalid fields for "records" parameter. |
href |
string |
_links
records
name |
string |
unix_group_users
name |
string |
records |
array[records] |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
