Create an Ethernet switch
Creates an Ethernet switch to integrate it into your network infrastructure, specifying its name, IP address, and model. Use this endpoint to configure monitoring and assign network roles for optimized management and operations.
HTTP method and endpoint
POST /network/ethernet/switches
Introduced in
ONTAP 9.11
Required properties
name- Name of the switch to create. -
address- Switch IP address. -
model- Switch model number. -
monitoring.enabled- Whether the switch should be monitored by CSHM. -
network-
cluster for cluster or shared switches.
storage for storage switches.
management for management switches.
snmp.version- SNMP version. -
snmp.user- SNMP user.
Related ONTAP commands
system switch ethernet create
Learn more
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
address |
string |
IP Address. |
discovered |
boolean |
Discovered By ONTAP CDP/LLDP
model |
string |
Model Number. |
monitoring |
name |
string |
Name. |
network |
string |
Switch Network. |
serial_number |
string |
Serial Number. |
snmp |
version |
string |
Software Version. |
Example request
"address": "string",
"model": "string",
"monitoring": {
"reason": "string"
"name": "string",
"network": "string",
"serial_number": "string",
"snmp": {
"user": "string",
"version": "string"
"version": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
12517376 |
Model number validation failed. Specify correct model number and try the command again. |
12517377 |
IP address "{address}" is not reachable. Verify that the address is valid or check the network path. |
12517379 |
SNMP validation request timed out. Verify that the "snmp.user" parameter is valid. |
12517381 |
SNMP validation request timed out. Verify that the "snmp.user" parameter is valid (i.e., the SNMPv3 user exists in ONTAP and on the remote switch). If the "snmp.user" parameter is valid, verify that the SNMPv3 user's credentials are the same both in ONTAP as well as in the remote switch. If a custom engine-id was provided for the SNMPv3 user, ensure it is the same as that of the remote switch. |
12517383 |
Switch type "{network}" is not valid for specified switch model "{model}". |
12517384 |
SHM is already monitoring a switch with IP address "{address}". |
12517385 |
Model "{model}" is unknown. Use "OTHER" if the switch model is not one of the following: {models}. |
href |
string |
self_link
monitoring
enabled |
boolean |
Enable Health Monitoring. |
monitored |
boolean |
Is Monitored. |
reason |
string |
Reason For Not Monitoring. |
snmp
user |
string |
Community String or SNMPv3 Username. |
version |
string |
SNMP Version. |
switch
Ethernet Switch REST API
address |
string |
IP Address. |
discovered |
boolean |
model |
string |
Model Number. |
monitoring |
name |
string |
Name. |
network |
string |
Switch Network. |
serial_number |
string |
Serial Number. |
snmp |
version |
string |
Software Version. |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
