Create an Ethernet switch
Adds an Ethernet switch to your network configuration. This is used to manage and monitor switch settings, such as SNMP details and network roles, enhancing your network's operational scope.
HTTP method and endpoint
POST /network/ethernet/switches
Introduced in
ONTAP 9.11
Required properties
name- Name of the switch to create. -
address- Switch IP address. -
model- Switch model number. -
monitoring.enabled- Whether the switch should be monitored by CSHM. -
network-
cluster for cluster or shared switches.
storage for storage switches.
snmp.version- SNMP version. -
snmp.user- SNMP user.
Related ONTAP commands
system switch ethernet create
Learn more
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
address |
string |
IP Address. |
discovered |
boolean |
Discovered By ONTAP CDP/LLDP
model |
string |
Model Number. |
monitoring |
name |
string |
Name. |
network |
string |
Switch Network. |
rcf_version |
string |
The switch reference configuration file (RCF) version. |
role |
string |
Switch role based on the interface configurations. Using '+' to combine multiple roles. Available role types are: cluster, multicluster, storage, multistorage, metrocluster. |
serial_number |
string |
Serial Number. |
snmp |
version |
string |
Software Version. |
Example request
"address": "string",
"model": "string",
"monitoring": {
"reason": "string"
"name": "string",
"network": "string",
"rcf_version": "RCF NX9336C-FX2 v1.13 1-CLUSTER",
"role": [
"cluster+storage"
"serial_number": "string",
"snmp": {
"user": "string",
"version": "string"
"version": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636148 |
Failed to discover SNMPv3 engine ID of the remote switch. |
5636149 |
The " |
5636152 |
0.0.0.0 cannot be specified as the IP address for the " |
8912900 |
Invalid IP address. |
9044009 |
SNMPv3 client feature is not available until the effective cluster version is ONTAP 9.3 or later. |
12517377 |
Model number validation failed. Specify the correct model number and try the command again. |
12517378 |
The IP " |
12517380 |
SNMP validation request timed out. Verify that the " |
12517382 |
SNMPv3 validation request timed out. Verify that the " |
12517384 |
A switch with the same IP address is already being monitored. |
12517385 |
The " |
12517411 |
The input value for " |
href |
string |
self_link
monitoring
enabled |
boolean |
Enable Health Monitoring. |
monitored |
boolean |
Is Monitored. |
reason |
string |
Reason For Not Monitoring. |
snmp
user |
string |
Community String or SNMPv3 Username. |
version |
string |
SNMP Version. |
switch
Ethernet Switch REST API
address |
string |
IP Address. |
discovered |
boolean |
model |
string |
Model Number. |
monitoring |
name |
string |
Name. |
network |
string |
Switch Network. |
rcf_version |
string |
role |
string |
serial_number |
string |
Serial Number. |
snmp |
version |
string |
Software Version. |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
