REST API reference
Create an Ethernet switch
Creates a new Ethernet switch to define its network configuration and enable monitoring. This is useful for managing switch connectivity and SNMP settings in your network infrastructure.
HTTP method and endpoint
POST /network/ethernet/switches
Introduced in
ONTAP 9.11
Usage notes
Creates an ethernet switch.
Required properties
  • name - Name of the switch to create.
  • address - Switch IP address.
  • model - Switch model number.
  • monitoring.enabled - Whether the switch should be monitored by CSHM.
  • network
    • cluster for cluster or shared switches.
    • storage for storage switches.
    • management for management switches.
  • snmp.version - SNMP version.
  • snmp.user - SNMP user.
  • system switch ethernet create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
address
string
IP Address.
discovered
boolean
Discovered By ONTAP CDP/LLDP
  • readOnly: 1
  • Introduced in: 9.8
  • x-nullable: true
model
string
Model Number.
monitoring
monitoring
name
string
Name.
network
string
Switch Network.
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
Example request
  "address": "string",
  "model": "string",
  "monitoring": {
    "reason": "string"
  "name": "string",
  "network": "string",
  "serial_number": "string",
  "snmp": {
    "user": "string",
    "version": "string"
  "version": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
5636149
"{snmp.user}" must be a valid SNMPv3 user belonging to remote switch with IP address "{address}" and must also be configured in ONTAP.
12517377
Model number validation failed. Specify correct model number and try the command again.
12517378
IP address "{address}" is not reachable. Verify that the address is valid or check the network path.
12517380
SNMP validation request timed out. Verify that the "snmp.user" parameter is valid.
12517382
SNMP validation request timed out. Verify that the "snmp.user" parameter is valid (i.e., the SNMPv3 user exists in ONTAP and on the remote switch). If the "snmp.user" parameter is valid, verify that the SNMPv3 user's credentials are the same both in ONTAP as well as in the remote switch. If a custom engine-id was provided for the SNMPv3 user, ensure it is the same as that of the remote switch.
12517384
Switch type "{network}" is not valid for specified switch model "{model}".
12517385
SHM is already monitoring a switch with IP address "{address}".
12517386
Model "{model}" is unknown. Use "OTHER" if the switch model is not one of the following: {models}.
string
monitoring
enabled
boolean
Enable Health Monitoring.
monitored
boolean
Is Monitored.
reason
string
Reason For Not Monitoring.
snmp
user
string
Community String or SNMPv3 Username.
version
string
SNMP Version.
switch
Ethernet Switch REST API
address
string
IP Address.
discovered
boolean
  • readOnly: 1
  • x-nullable: true
model
string
Model Number.
monitoring
monitoring
name
string
Name.
network
string
Switch Network.
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
