Add a reporting node and its HA partner to a LUN map
Adds a reporting node and its HA partner to an existing LUN map. Use this endpoint when you need to enhance LUN access through additional nodes for improved redundancy or performance.
HTTP method and endpoint
POST /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}/reporting-nodes
Introduced in
ONTAP 9.10
Usage notes
Adds a reporting node and its HA partner to a LUN map.
Required properties
uuidorname- A cluster node to add.
Related ONTAP commands
lun mapping add-reporting-nodes
lun.uuid |
string |
path |
True |
The unique identifier of the LUN. |
igroup.uuid |
string |
path |
True |
The unique identifier of the igroup. |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
igroup |
The initiator group of the LUN map of the reporting node. |
lun |
The LUN of the LUN map of the reporting node. |
name |
string |
The name of the node. Either |
uuid |
string |
The unique identifier of the node. Either |
Example request
"igroup": {
"lun": {
"name": "node1",
"uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[lun_map_reporting_node] |
"num_records": 1,
"records": [
"igroup": {
"lun": {
"name": "node1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374875 |
The specified LUN does not exist or is not accessible to the caller. |
5374878 |
The specified initiator group does not exist, is not accessible to the caller, or is not in the same SVM as the specified LUN. |
5374920 |
The specified cluster node does not exist. |
5374921 |
The specified cluster node name and UUID do not refer to the same cluster node. |
5374922 |
The specified LUN map does not exist. |
5374923 |
A cluster node |
href |
string |
_links
igroup
uuid |
string |
The unique identifier of the initiator group. |
lun
uuid |
string |
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
igroup |
lun |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
