REST API reference
Add a reporting node and its HA partner to a LUN map
Adds a reporting node and its HA partner to a LUN map to configure SAN access paths for optimized data access. This is useful when setting up or expanding the storage network for efficient load balancing and redundancy.
HTTP method and endpoint
POST /protocols/san/lun-maps/{lun.uuid}/{igroup.uuid}/reporting-nodes
Introduced in
ONTAP 9.10
Required properties
  • uuid or name - A cluster node to add.
  • lun mapping add-reporting-nodes
lun.uuid
string
path
True
The unique identifier of the LUN.
igroup.uuid
string
path
True
The unique identifier of the igroup.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
_links
_links
igroup
igroup
The initiator group of the LUN map of the reporting node.
lun
lun
The LUN of the LUN map of the reporting node.
name
string
The name of the node.
Either uuid or name are required in POST.
uuid
string
The unique identifier of the node.
Example request
  "igroup": {
  "lun": {
  "name": "node1",
  "uuid": "5ac8eb9c-4e32-dbaa-57ca-fb905976f54e"
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[lun_map_reporting_node]
  "num_records": 1,
  "records": [
      "igroup": {
      "lun": {
      "name": "node1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The specified LUN does not exist or is not accessible to the caller.
5374878
The specified initiator group does not exist, is not accessible to the caller, or is not in the same SVM as the specified LUN.
5374920
The specified cluster node does not exist.
5374921
The specified cluster node name and UUID do not refer to the same cluster node.
5374922
The specified LUN map does not exist.
5374923
A cluster node uuid or name must be specified to add a reporting node.
5376454
Modifying reporting nodes of a LUN map is not supported on this platform.
string
igroup
uuid
string
The unique identifier of the initiator group.
lun
uuid
string
A cluster node from which network paths to the LUN are advertised by ONTAP via the SAN protocols.
_links
_links
igroup
igroup
lun
lun
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
